» Tire Upgrade Garage
Old 02-17-2008, 07:21 AM   #81 (permalink)
NCFJ's Avatar
Member Number: 8585
Re: CLEAN 12v Fuse Block Accessory Install w/Pics
I made three different sized mounting plates before I came up with the one I needed. I have the patterns outlined and have FAXed them to a couple members. If you want the patters PM me and I can FAX them to you.
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
NCFJ is offline
Old 04-09-2008, 04:27 PM   #82 (permalink)
ArmyMedic's Avatar
Member Number: 11180
Send a message via Yahoo to ArmyMedic
This is ALMOST exactly what I need...my only problem is I want the power to all of my "stuff" cut off when the key is off... is there an easy patch for that?
07 Ti FJ
Gobi Ladder, Dakkar Combo Light Bar, PIAA 540's (x4), OEM Rockrails, Wet Oakoli Seat Covers, K&N Filter, 3" RevTek Leveling lift, 285x70x17 AT's, Scanguage, SwissArmySUV's map light, BudBuilt Skids, TRD CAI
"The secret nature of my job prevents me from knowing what I am doing"
ArmyMedic is offline
Old 04-09-2008, 05:31 PM   #83 (permalink)
NorCalCruiser's Avatar
Member Number: 18568
Great job, I know what you mean with the wiring, I have mild OCD.
NorCalCruiser is offline
Old 04-09-2008, 08:11 PM   #84 (permalink)
doublejfj's Avatar
Member Number: 17287
ArmyMedic previously said: View Post
Yes, you just add a relay on the main power coming into the fuse panel. Then use an add-a-circuit to switch it on with an ignition source.
Bingo, instant switched fuse panel.
J+J+FJ
'08 Ti Manual - OME 895/886, TG Sliders, CB & Bandi, Magellan Crossover GPS, Hi-Lift, Backup Cam, other assorted super stealth accessories
doublejfj is offline
Old 04-11-2008, 09:05 AM   #85 (permalink)
The Unfunny Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Location: AZ boy (temporarily) transplanted to southeast GA.
Here ya go . . . .
12-Circuit "Switched" Fuse Block (Installation w/ pics)
Steve
A few '07 Sun Fusion mods . . .
(Sun Fusion can either be
good or bad.)
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is online now
Old 04-21-2008, 08:45 AM   #86 (permalink)
ArmyMedic's Avatar
Perfect! Thanks!
07 Ti FJ
Old 05-15-2008, 04:01 PM   #87 (permalink)
Member Number: 19043
Looks great. One thing though, I am an electrician and if you are going to go with a 60 amp fuse you should probably up grade to #6 awg wire which is good for about 50 amps. #10 awg wire is only rated for 30amps. more than likely it wont be an issue., but you know "what if"?
08' brick w/ daystar 2 1/2" leveling, dice ipod mod.
CORYRSNOWMAN is offline
