Old 01-15-2008, 09:01 AM   #51 (permalink)
Member Number: 16972
Re: NEW WICKED CAS REAR SPEAKER PODS. Solution for rear speaker placement.
The link is for the pods without speakers. How can I order with the TR650-CXi Coaxials at the price you sent me in the PM?
Also, do you have installation instructions for these pods?
wadayem is offline
Old 01-15-2008, 03:34 PM   #52 (permalink)
Nazar's Avatar
Member Number: 6383
wadayem previously said: View Post
Sorry Just send a payment to
paypal@wickedcas.com
"Payment for FJ REAR PODS AND TR650 COZ+XIALS"
copy and paste the above Quote with payment.
Nazar
Home of Custom Fit Fiberglass Subwoofer Enclosures, We call them "MagicBox" http://www.fjcruiserforums.com/forum...icked-cas.html
NOW AVAILABLE FOR YOUR FJ CRUISER IN 1X12" or 2X10" Configurations.
JL AUDIO, FOCAL, KENWOOD, MEMPHIS, DYNAMAT, COMPUSTAR, CLIFFORD, AUDISON, ACCESSORIES PARTS AND MUCH MORE. Please call us with any needs for great service and unbeatable savings. 603-642-4222
Nazar is offline
Old 01-17-2008, 12:56 AM   #53 (permalink)
Nazar previously said: View Post
Nazar
Done. Now I'd appreciate it if you can share detailed installation instructions.
wadayem is offline
Old 01-17-2008, 08:24 AM   #54 (permalink)
Nazar's Avatar
Member Number: 6383
It is very easy.
You will need some cutting tools, Drill bit, Drill, and a Phillips bit (which you will anyways for speaker install)
When cutting holes be carefull not to cut anything behind factory panels, It is clear there but the hinge might interfere if you use a long cutting blade. Just measure twice before cutting. If you mess up a little our pods will cover it, However you want to make sure you do not cut more then you need so you can screw the panels in. If however you do you van use Heavy duty double sided tape. Let's hope you don't get to that point.
Place our Wicked CAS FJ REAR PODS on the panels so that they are sitting flush and comfortably in place.
Mark the opening for the whole.
Take the pods off the panels.
Cut out the marked (Circled) area.
Place the pods back on the panels.
Place the speaker and the grille assembly on the pods and on Factory panels.
Mark your screw holes.
Drille a pilot hole for the mounting screws. You will need to hold to FJ PODS in place for this so that they won't move on you. You can also use double sided tape on the back to make sure they don't move in this process.
I suggest using a speed clip from behind the panel HOWEVER NOT NECESSARY, You can do it without the speed clips. Using a speed clip may require the panels to be off thecar, But you can do ithis without the panels off the car. That is all up to you...
Screw the speakers in through the PODS and into the panels. I suggest doing this with a Screw driver. Using a drill may strip the mounting hole. Use a Screw driver and you get a better feel when it is tight enough.
Nazar is offline
Old 02-25-2008, 03:31 PM   #55 (permalink)
RDavidW's Avatar
Member Number: 7910
Hey Nazar,
What is the best way to remove the panels the pods go into? I want to dynamat behind them. Should I remove the back seats? Do I need to remove the rear seatbelts? I have the doorsill trim off. Thanks for your help.
Dave
RDavidW is offline
Old 02-25-2008, 03:56 PM   #56 (permalink)
RDavidW's Avatar
Member Number: 7910
One more question - for my drivers side sub, should I cut a hole in the panel for the speaker wire or run it around to the back?
Thanks again
Dave
Dave
RDavidW is offline
Old 02-25-2008, 08:10 PM   #57 (permalink)
Giddens2k's Avatar
Member Number: 4245
Just went to your site and ordered a set. Can't wait to get these pods in. Thank you Nazar.
Giddens2k is offline
Old 05-28-2008, 11:54 AM   #58 (permalink)
Nazar's Avatar
Member Number: 6383
We now try to stock these for a faster turn around.
Nazar is offline
Old 07-10-2008, 09:23 AM   #59 (permalink)
Nazar's Avatar
Member Number: 6383
This has got to be the Best bang for th ebuck mod ever for the FJ. Result you get with these pods and new rear speakers are a night and day. At least that is all of yous are telling me. 100 % satisfaction guarantee with these pods. over 40 Rear pods in use and they are all getting great reviews.
Nazar is offline
