Old 05-29-2007, 03:52 PM   #1 (permalink)
S2bear's Avatar
Member Number: 9648
Send a message via Skype™ to S2bear
12v Socket fits in driver's glovebox here (photos):
Here's where I fitted a 12 volt accessory socket in the driver's glovebox. There are other posts on here separately detailing how to remove the glovebox and how to add a 12v socket. Combine the two and you have this.
As far as I could tell, this was the only place to add the socket without fouling the hinges or screws: Inside right glovebox wall, nearest to the steering wheel.
1. Removed Driver Glovebox (see here): Drivers glovebox removal??
2. Removed FJammer for access (see here):iPod connected directly to FJ Jammer - Installation Instructions
3. Drilled a hole in the right hand side wall of the drivers glovebox - I used a 30mm hole saw for my socket but yours may require a different size.
DON'T DRILL TOO CLOSE TO THE TOP OF THE GLOVEBOX/DASH as the socket probably has a 'collar' which fitted from the rear side to hold it in place - this will be larger than the hole and won't fit if you're too close to the top lip.
4. I replaced the glovebox and 'trial' pushed the socket thru the hole (has to be done in that order, or the box won't go back into place). The socket hit some plastic infrastructure on the underside of the dash - I used a dremmel to remove this plastic, really carefully. removed a bit, then refit, remove refit etc. until there's enough clearance.
5. Replaced glovebox and passed wires up thru the access hole created by removing the FJammer, stuck them thru the new hole in the glovebox and spade connected them onto the back of the socket.
6. Fitted socket into hole and slide collar along the wires and onto the back of the socket - that's the socket bit done.
7. Threaded the wires along to the interior fusebox (at knee level by drivers door) and tapped a live feed from there via an inline fuseholder.
The worst bit of the job was 'dremmelling' the underside of the dash but this was probably because I wasn't sure that this was all gonna work.
Sorry if this has been posted by someone already and thanks to the guys that posted the linked threads above - I probably wouldn't have attempted this without those threads. I'm no qualified auto 'anything' so attempt at your own risk, but hopefully the pics will be of use.
Will post more pics - sorry if some are a little puzzling!!!
Stu
12v-socket-fits-driver-s-glovebox-here-photos-dsc_0199.jpg  12v-socket-fits-driver-s-glovebox-here-photos-dsc_0202.jpg  12v-socket-fits-driver-s-glovebox-here-photos-dsc_0200.jpg  12v-socket-fits-driver-s-glovebox-here-photos-dsc_0201.jpg  12v-socket-fits-driver-s-glovebox-here-photos-dsc_0206.jpg
Never interrupt your enemy whilst he's making a mistake - Napoleon Bonaparte
Diamond Black, PKG2, Auto 4wd
AR Teflon Chamber 17x9 & 285/70 17 Cooper STT
Body mount chop
TRD CAI
Light bar & 6xKC slimlites (2pencil, 4driving)
Gobi Ladder, Yakima FatCat6
Dice box
12v drivers glovebox
Donahoe Coilovers in box, in living room.... in trouble... (not installed yet)
S2bear is offline
Old 05-29-2007, 03:57 PM   #2 (permalink)
S2bear's Avatar
Member Number: 9648
Re: 12v Socket fits in driver's glovebox here (photos):
a few more pics of the socket and the view under the dash towards the passenger side....
12v-socket-fits-driver-s-glovebox-here-photos-dsc_0212.jpg  12v-socket-fits-driver-s-glovebox-here-photos-dsc_0198.jpg  12v-socket-fits-driver-s-glovebox-here-photos-dsc_0209.jpg
Body mount chop
TRD CAI
Dice box
S2bear is offline
Old 05-29-2007, 04:15 PM   #3 (permalink)
Silverdusk's Avatar
Member Number: 4660
Very nice!! Thanks for posting.
Silverdusk is offline
Old 05-29-2007, 11:29 PM   #4 (permalink)
Mrcat88's Avatar
Member Number: 9870
Clean! Nice work!
Thanks for the pics! Keep them active please, for future reference.
Stop Hercu-raping your vehicle! Use a REAL product for REAL results! DURABAK!
Mrcat88 is offline
Old 05-30-2007, 03:52 AM   #5 (permalink)
EARL97850's Avatar
Member Number: 4649
Great idea...very clean install.
Cya
EARL97850 is offline
Old 07-26-2007, 04:28 PM   #6 (permalink)
Slingerdoo's Avatar
Member Number: 12089
S2bear,
Thanks for the details. I just did the install in just over an hour (taking my time) and it works perfectly!
TLCA Member #17804
Tread Lightly
KI4PSH
Slingerdoo is offline
Old 07-26-2007, 04:33 PM   #7 (permalink)
chewey46's Avatar
Member Number: 292
Nice, I would give you rep points if I had any left to give today.
[YOUTUBE]
http://www.youtube.com/watch?v=ZPzUx...eature=related
A cross between quasimoto and the elephant man..... But only the good parts!!!!!
Hello chewey46 it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
chewey46 is offline
Old 10-15-2007, 04:57 PM   #8 (permalink)
Canteen's Avatar
Member Number: 12218
Great location...
Never thought about the spare glove box; kept wrapping myself around the axle with placing the extra 12v outlets in console.
Sun Fusion,
Factory roof rack,
Revtek 3" lift,
33" BFG Mudders,
All-pro rock rails,
Wilderness shovel-axe & High-lift rack accessories...
Canteen is offline
Old 10-15-2007, 05:00 PM   #9 (permalink)
pokerDawg's Avatar
Member Number: 12463
I like it. I'll drop my FJ off in the morning. Do you take Visa?
My FJ Cruiser videos on YouTube and Vimeo
pokerDawg is offline
Old 10-15-2007, 09:21 PM   #10 (permalink)
merlinridesagain's Avatar
Member Number: 6952
Nice work!
I agree the dremmelling the dash to get the socket to fit takes some work. There is a fair amount of plastic to remove.
Build Up Notes
merlinridesagain is offline
