I'm not sure what you mean by "Mods" to a CB. What can you mod?
My Cobra 29 Nightwatch.
Built in SWR meter, similar to the one USMC just bought, but mine is from '99 or so.
The bigger Cobras, the 25 and 29 series you can change out the amp chip in there and 5x the power.
A normal CB put out around 5 watts maximum when you push the button.
Mine is putting out around 25 watts when I key up.
I do not use it on the highway much unless to ask about slowing down traffic.
I mainly use it for off road, and with the extra power I can punch through the mountains with ease.
__________________ Corey 2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, to much to list, see my website & buildup thread
I almost went with the Nightwatch I saw one that had the WX option.. I really wanted the weather channels but oh well.. Much like you, I figured I would want to amp it up cause of the terrain. But that can get $$$.
Corey did you use the std mount, I think that comes with it.. if not I'm thinking that I will need to buy one.
Tell me more about preferred antenna locations and the mounting bracket. Post some pictures if you have them please.
I've put cb's on most of my motorcycles. I have a 4' Firefly and a 4' Firestick at home that I'm not using ---- too tall? They stressed the mount too much on my bike and I had to put a smaller mast on it.
btw, I'm almost always on 19 when I ride solo; truckers are a wealth of information and entertainment. Channel 1 is the motorcycle channel.
What channel for ORV's?
Yeh, I have the Large Single Side Band Cobra 148 NW ST, I made a bracket for it along the passenger side, check out the link below.
USMC_Sgt previously said:
Yep what Corey said on the mod's
Or you can make one like I did, I posted the dim for a templete.
squirrelly previously said:
I used search but couldn't find more installs.
I would use the BANDI CB Mount!..Awesome, made just for the FJ, it looks stock. You can buy it from one of our venders All Pro.
I have a Connex General Lee CB from Radio Active Radios. It puts out about 60 watts, I mounted the CB in the roof. If you search "Regreb" post titled "Roof Mounted CB Install",it works well with a big radio and is prety easy to do,heck I did it. The Bandi mount is asome if you can get one. If you want to learn more about CB radios check out www.cbradiotalk.com That forum has lots of info. Remember if your going to Ouray monitor chanel 7.
