Old 09-02-2007, 12:59 AM   #1 (permalink)
Cruzer's Avatar
Member Number: 3483
Can 1 4-chanel amp run all 8 speakers?
Hey guys,
If I install a 4 channel amp to the harness behind the stock deck will it be able to drive all 8 speakers? From what I've seen in the wiring diagrams it looks like the 4 fronts are tied together and run off the same channel and the roof and rear pillars tie into the two rear channels.
I'll be running a small kicker amp 35 watts per channel and I've replaced all speakers with JBLs, (except for the roof speakers).
Will this work or do I have to run all new wires from the new amp? I did a search but couldn't find anything specific.
Thanks in advance,
~C
Cruzer is offline
Old 09-02-2007, 01:54 AM   #2 (permalink)
Bappy's Avatar
Member Number: 12552
Re: Can 1 4-chanel amp run all 8 speakers?
if the amp is stable at 2 ohms you will have no problem. You should be fine running all 8 speakers.
2007 Black Diamond 4x4 285/65/18 Motometal and cooper LTZ's Simply SICK PEOPLE SICK!
Bappy is offline
Old 09-02-2007, 01:57 AM   #3 (permalink)
AceTechno's Avatar
Member Number: 4098
Ya, why not? Most car stereo amps can drive a 2 ohm load.
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
AceTechno is offline
Old 09-02-2007, 01:01 PM   #4 (permalink)
Cruzer's Avatar
Member Number: 3483
Cool... the amp can drive at 2 ohms so I'll give it a shot!
~C
Cruzer is offline
