As I posted it on diymobileaudio.com
Well, I guess I'll post part 2 of my install which is the sub-floor. I have to forewarn. I'm always a little ashamed to post my installs on this site because the work that many of the members do here makes my capabilities look like I belong on the short bus. With that being said, I think that it's nice for people to also see every day installs for those that may be reluctant to tap into their ride because they know they don't have the skills to match some of what they see on this site. So here it is folks, the common man's install!
My goals for the entire install are:
-Stealth
-Able to withstand off-roading, dogs, kids, camping, winter ect for the next 100,000 miles if I so choose.
-Taking up minimal storage space
- Able to house 3 amps, processor, power/ground distribution and fans
I decided the only way to meet these goals, considering the size of my amps in particular, was to build a sub floor. It's not finished yet. It needs the roll on bed-liner applied and a few more final details. Right now it's just primer.
Here is what the stock FJ looks like in the back. This is not mine, it's a stock photo because I forgot to snap a pic before I anxiously ripped it apart.
Stripped
You can see the three pedestals in the back. I need to have the sub-floor extend over these because otherwise there is a large gap between the seat and the sub-floor.
1/2" Birch ply for the top
Lucky for me Toyota made them 3/4" tall and I have a lot of 3/4" MDF laying around
Looks pretty level to me
The sub-floor uses 4 factory mounting holes. You can see bolts in the back for two of them. You can also see my mock up of the sides.
My ventilation will come from this gap at the back where it can draw air from under the rear seats.
I had to use two pieces of wood because I was using this 1/4" hardboard I had on hand but it wasn't big enough. I'm using the 3/4" underneath for support which sits directly on the bottom of the FJ so there is plenty of support.
I used 3" wide 3/4" thick Poplar slats for the sides. Here is the first side being glued 'n screwed and clamped and sitting upside down.
Since the front corner of the plastic in the FJ is curved, I couldn't make square corners on the floor and still have the box cover all the floor area so I made the corners like you see below. My craftsmanship here (or lack-there-of) really comes through. Anyways, a picture is worth 1000 words right?
I used a file and a razor-knife to hand make the pices and put them in place with copious amounts of wood glue. All in all, although I don't think they turned out perfect by any stretch, I
am happy with how it turned out. It obviously need sanding at this point.
