Okay, this is not FJ related, but I need some help please. We bought my sister a sub and box plus wiring for her civic for her birthday today.
It isn't working...
I have installed a few subs before, so I think I've done everything right
Here are the connections on the amp:
1. Remote: Supplies 12V to Amp when headunit is on as a switch (had no wiring schematic so I tested wires with my multimeter, the red on on her harness was 0 when headunit was off and 12V when unit was on)
2. 12V: Powers amp. Fusible link installed, wired to battery with some thick wire.
3. Ground: Duh. Grounded to brake light assembly M5 threaded stud.
4. To Sub connections: My amp is a 2 channel with a bridged switch. Switched to bridged and used bridged + and - connections.
5. Sub outs (RCA style audio plug): From sub out on deck to audio in on amp.
The amp is getting power, and it worked fine in my pickup, and seems fine now, but no bass! The power light comes on when the deck is turned on, but still nothing. I checked everything a few times and all seems to be correct. Seems there is nothing getting to amp as a signal. All the connections are fine, confirmed with my multimeter. I think the problem is the head unit. It says on it, since she lost the documentation "Selectable Sub out." This is a newer Xplod deck. Anyone know where I can find out if the deck can turn the sub outs on? What kind of readings should I get from the RCA cables? Seem to be nothing coming out.
Please help! Thanks
