Old 05-01-2006, 09:35 PM   #11 (permalink)
gsgmac's Avatar
Member Number: 1534
Re: Anyone removed the driver's side storage box?
Took my "gat box" out yesterday and it does make for easy access to the back of the gauges. I was thinking of putting a 12v outlet in there, but no go. The only way it would fit is from the bottom facing up. Then you are just asking for something to fall in there and short it out!
Granger - Make sure to post pics and details about the wire for the speed sensor, I am sure others (including me) could use this info when installing our navigation systems....
1972 Freeborn Red FJ40 4x4
gsgmac is offline
Old 05-01-2006, 11:39 PM   #12 (permalink)
Chatsworth 818 FJ's Avatar
Member Number: 1770
Dang my, .50cal Desert Eagle, extended barrel, with red-dot scope, wont fit!!! First thing I found on my FJ I dont like.
Ps Anyone wanna trade some rock rails for my Bennelli m-1?
Chatsworth 818 FJ is offline
Old 05-14-2006, 09:11 AM   #13 (permalink)
Member Number: 1908
Location: bouncing between richmond va and woodbridge va
Send a message via Yahoo to dirtycruiser
im 99% sure you can get the VSS wire in the back of the radio coming from the steering wheel control harness.Toyota ALWAYS puts these there iun all their cars.My scion xb(delivery car for work) had one there and it doesnt even come with a option for nav.also did you guiys know that the camry navigation will plug and play into an fj?
dirtycruiser is offline
Old 05-14-2006, 09:46 AM   #14 (permalink)
Audiox's Avatar
Member Number: 2088
VSS
Purple/Red at fuse box rear 4 pin plug pin #1
Also found at the ECM (Engine Control Module) behind the glovebox, second plug from the bottom, pin 8.
Audiox is offline
Old 06-22-2006, 08:54 PM   #15 (permalink)
SoonerFJ's Avatar
Member Number: 2501
gsgmac, I was able to install a 12v outlet in the driver's gat box by placing the outlet horizontally in the lower right corner (the one away from the windshield on the right side). It fit perfectly between the two ribs and I only had to trim a small amount of plastic in the dash behind the outlet for it to fit underneath the dash and through the cut hole.
The sneaky part, was to re-install the box after you cut the hole, and then push the outlet through from the inside once the box is bolted in. Only minimal trimming was needed to remove about 1 inch worth of plastic in the dash before re-installing the box. Everything is still solid, and no factory mounting points were lost by cutting the dash plastic.
I used the ground wire behind the switchplate underneath the radio, and ran the hot wire directly to the fuse box. (Thanks to instructions on installing an outlet in the console from other members!)
This gives me ability to charge things without having the ignition on and to hide the goodies from prying eyes at the same time.
SoonerFJ is online now
Old 06-22-2006, 11:59 PM   #16 (permalink)
Moderator
Ridge111's Avatar
Member Number: 2612
Why would a GPS need to be connected to the speed sensor. The GPS knows how fast it's going.
Ridge111 is offline
Old 06-23-2006, 12:13 AM   #17 (permalink)
Member Number: 2086
Try a S&W 640 - fits nicely.
rick_reno is offline
Old 06-23-2006, 12:37 AM   #18 (permalink)
FJ4me's Avatar
Member Number: 1651
Send a message via Yahoo to FJ4me
Chatsworth 818 FJ,
The G19, Sig P229 or the HK USPC would be a perfect fit for the "gat box".
Wish I had rock rails for your M1 but I'd keep that M1. I love my M1014 Limited and will never part with it!
Sorry about that people...
Back to the topic.
FJ4me is offline
Old 06-23-2006, 05:25 AM   #19 (permalink)
Member Number: 1136
On a side note, I found that stuff in this box gets really hot. Even tried some stick on mylar bubble insulation in the lid but I think it's the lack of air circulation.
So I wouldn't recommend keeping an iPod, GPS or cell phone up there.
Albemarle is offline
Old 06-23-2006, 06:18 AM   #20 (permalink)
FlyBriz's Avatar
Member Number: 2434
Might want to lay a towel or something down when you pull that box - I managed to give myself a little scratch on the dash with the clips on the bottom of the box as I pulled it out. Better safe than sorry!
FlyBriz is offline
