I am about to start a weeklong build to finish my interior before the Pomona Offroad Expo, where my truck is gonna be in the Toyota booth. So I beg the help of you gurus to come to my rescue.
The help I need is with connecting the amps and crossovers, and reconstructing the Eclipse head unit harness. Everything will be mounted; I'm just scared of blowing it up when I wire it all in, and that's why I'm posting.
The original install was probably the worst one ever done in history, and I just finished ripping it all out. Al & Ed's in Aliso Vejo, Calif. It's amazing the car didn't burn to the ground. Open wires twisted together, MB Quart crossovers crammed up hard into the dash, breaking other wires. For the first month I had it, it was all running mono and I couldn't figure out where the problem was. My favorite was that you would see monster cable connected to an amp or something, but when it ran into a hidden area like under the floor, it would be spliced into tiny cheap speaker wire. They also shredded the factory harness and the Eclipse harness. Here is how it looked when we first took the dash off:
OK, fast forward to today:
My new interior has a cage that allows us to mount the 2 PDX's and 5 crossovers in the ceiling. In the front are MB Quart 3-way, and the back pillar has the 2-way. Then there are two JLA W3 10's in boxes. Here is a diagram of the ceiling and cage tubes. The amps are in the back.
Here is the cage, and you can see the relation to the diagram above:
This is all I have, and a bunch of monster cable. I have no diagrams or anything, just extra wire, soldering iron and connectors.
The PDX's are both the 4/150. One of them has only two inputs so I assume that one's for the subs. Four of the crossovers have both high and low pass and one of them is just a high pass so I guess that's correct too.
Also I should mention the way it will be finished off. I have some custom black PVC high density foam (1/2") with adhesive backing. This will cover up the tubes and the ceiling, so it will all look black. However we will go around the amps and crossovers of course. I also have 2 shop packs of Second Skin Overkill and am worried about where the heck I am gonna put that stuff as well. I have a ton of Damplifier Pro in there as you can see, and wonder where and how I can apply the Overkill over that, if secondskinrep is reading this.
Here is what the front end looked like in better days. Believe it or not it has to look like this, and much more, by the end of next week:
