Old 11-18-2006, 11:05 PM   #121 (permalink)
HUDsFJ's Avatar
Member Number: 7296
White Rim previously said: View Post
I use these
THat way I do not have unfused wires running around. I hate the smell of burning insulation.
I do not double up the fuses like you can do, I just use them to tap off with a fused wire.
Dang That's the ticket. Where do you find something like that? Auto Zone? I hope so. I have been kinda leary about plugging a spade terminal, which I did and its working, into just the top portion of a fuse receptacle. The only reason I did it was that the 12v outlet has an inline fuse but I would much rather pay another couple bones to get one of these.
I guess a sense of security none the less.
Thanks,
MO
HUDsFJ is offline
Old 11-19-2006, 12:53 AM   #122 (permalink)
etp095's Avatar
Member Number: 971
i just looked up the web site.
Battery & Fuse Block Accessories - Wirthco Engineering, Inc.
etp095 is offline
Old 11-19-2006, 09:27 AM   #123 (permalink)
HUDsFJ's Avatar
Member Number: 7296
etp095 previously said: View Post
Yeah was just hoping to pick it up locally not the type of thing one usually orders on the internet.
Thanks,
MO
HUDsFJ is offline
Old 11-19-2006, 10:53 AM   #124 (permalink)
White Rim's Avatar
Member Number: 3435
they were available at a local electronics supply shop (not an auto shop).
Norvac. Maybe they take phone orders.
Norvac Electronics, Your Northwest Electronics Distributor
White Rim is offline
Old 11-19-2006, 01:46 PM   #125 (permalink)
ruebarb's Avatar
Member Number: 1493
HUDsFJ previously said: View Post
Thanks,
MO
Make sure you get the mini, I originally bought one of these and quickly found out that Toyota does not use the standard size fuse.
ruebarb is offline
Old 11-19-2006, 02:43 PM   #126 (permalink)
Noisycow's Avatar
Member Number: 3046
The mini fuses with the light emitting LED are pretty slick, they light up when the fuse is blown so it is easy to track down what fuse needs to be replaced.
Kill Yourself!! Note: My sig links are often offensive, raunchy or outside the bubble; clicking means leaving the forum; don't likey?, don't whiney. Only you control your browser. 'Pause' at the beginning of a video allows the buffer to fill and means a more pleasurable viewing experience.
Noisycow is offline
Old 11-21-2006, 02:58 PM   #127 (permalink)
bigbill25's Avatar
Member Number: 1293
ruebarb previously said: View Post
Do they make them in the mini style?
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 11-21-2006, 03:30 PM   #128 (permalink)
Member Number: 6807
yes they do. I have installed two, one for my fog lights (signal to the switch,didn't want to wire it through the headlights) and one for my Sirius radio. One is constant on and the other is switched with Ign. Very clean way to add a circuit.
pardoni is offline
Old 11-21-2006, 04:19 PM   #129 (permalink)
Noisycow's Avatar
Member Number: 3046
Bill - Norvac in Beaverton carries them - just fyi.
Noisycow is offline
Old 11-21-2006, 05:08 PM   #130 (permalink)
redfernsoljah's Avatar
Member Number: 6109
sealink 12volt
redfernsoljah is offline
