» Tire Upgrade Garage
Old 05-15-2006, 01:33 PM   #21 (permalink)
Member Number: 836
I am giving mine a shot tonight. My chosen location for the rear outlet is just above the AC plug in. I popped it out last night and besides the ribs on the back it should work perfectly.
Anyone know if there is constant power to the subwoofer?
2007 FJCruiser Black ARB/WARN/IPF/OME
1988 4Runner ARB
Scott9000 is offline
Old 05-15-2006, 03:11 PM   #22 (permalink)
colink1's Avatar
Member Number: 812
Send a message via MSN to colink1 Send a message via Yahoo to colink1
Love the locations used in both. I plan to install 2 "Sealink - 12 Volt Receptacles", one in each location described above, running both from the fuse panel. Pictures to follow.
Colink1 - Austin, TX
2007 Voodoo Blue 4x4 A/T CQ, AL, SF, S4, RR, DH, AL
2 12 volt sockets, aFe CAI, Piaa 520 (fr bumper)
Toyo Hood Protector, Aeroflow h-light covers, EP Battery Clamp
Infinity 3s-dash, 4s-rear, 6x9s-doors, (2) Hella Horns
Sirius Sporster Replay4, V1, FJ Center Console (KB Vodoo)
Gobi Stealth rack - 4 Delta 45 Driving lamps
Yakima kayak stackers and steel head bike rack
1990 Honda CRX Si 1.6L
1995 BMW 525i 5spd
colink1 is offline
Old 05-15-2006, 04:43 PM   #23 (permalink)
SwissArmySuv's Avatar
Member Number: 1693
Ruebarb, sorry just saw your note ....
I took a standard spade terminal and trimmed down the width with wire
cutters so it fits into the "incoming" side of the fuse slot and plugged 'er in.
The accessory outlet has an inline fuse, so no need for a second fuse.
SwissArmySuv is offline
Old 05-16-2006, 07:34 AM   #24 (permalink)
Member Number: 836
Still working on the wiring but I think it turned out nice.
1988 4Runner ARB
Old 05-16-2006, 09:21 AM   #25 (permalink)
bigbill25's Avatar
Member Number: 1293
Hey! That is nice. Was it completely flat behind that panel (i.e. no ribs)? It looks like you could mount up two:
Note: Photoshop Job...
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 05-16-2006, 10:22 AM   #26 (permalink)
Member Number: 836
There are slight ribs on the back. No problem to cut through with the hole saw. Plenty of room behind there for wiring etc - two could be added no problem. Nice use of the cloan tool BTW
The panel comes off easily - put a screw driver in the top and it just pops out.
1988 4Runner ARB
Old 05-16-2006, 12:45 PM   #27 (permalink)
ruebarb's Avatar
Member Number: 1493
Very nice, I don't have the inverter or the sub. I was thinking of adding a 12v in the same panel, was going to tap into the sub harness wiring for power, I think I'll need the sub switch to activate the wire though. I'm interested to see where you run the wires.
ruebarb is offline
Old 05-16-2006, 01:17 PM   #28 (permalink)
Member Number: 836
I am going to look for constant power in the sub harness. If I don't find any I will be running a amp size fused wire straight to the battery.
1988 4Runner ARB
Old 05-17-2006, 07:32 AM   #29 (permalink)
Member Number: 836
I did find constant power in the sub harness last night. I believe it's the white wire with a black stripe. It got dark so I didn't finish the install but that's good news for anyone wanting to add a port in the back without running a wire to the battery (or fuse box).
1988 4Runner ARB
Old 05-17-2006, 07:58 AM   #30 (permalink)
ruebarb's Avatar
Member Number: 1493
Nice work, but are you sure it is the white w/black stripe. In the front of the FJ, those were all the ground wires. Also did you need to have the sub button engaged?
ruebarb is offline
