Old 09-02-2006, 11:55 AM   #81 (permalink)
bigbill25's Avatar
Member Number: 1293
Nice Rue. I'm still wondering if you can access the 12V under the 'map box'. I would like to have the power cable coiled up in there, and pull it out when needed... Need to investigate...
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 09-05-2006, 10:11 AM   #82 (permalink)
ruebarb's Avatar
Member Number: 1493
I couldn't pull out my map box, tried 3 or 4 times, not coming out in one piece.
ruebarb is offline
Old 09-05-2006, 03:18 PM   #83 (permalink)
bigbill25's Avatar
Member Number: 1293
Hmmm... Guess we need to wait for the Garmin install instructions...
--Bill
Old 09-05-2006, 03:57 PM   #84 (permalink)
gascolator's Avatar
Member Number: 4247
I'd like to see a 12V outlet in the back, and for ALL 12V outlets
to stay on with the ignition off (got used to that in the AUDI, handy
for running cell-phones, etc. even if it did allow one to do something
dumb). For the back, I suspect one could easily tap the feed to the
inverter. But it still wouldn't be on full time. I wonder if the easiest
path would be to relocate the connections at the fuse box to make
them always on.
gascolator is offline
Old 09-06-2006, 07:32 AM   #85 (permalink)
ruebarb's Avatar
Member Number: 1493
them always on.
Tap the white/w blue strip wire on the sub harness, constant on for the rear if you add 12v. I don't have the inverter, so I installed 2 -12v plugs in the cover for where the inverter socket would be. Plus there is a factory ground next to the inverter.
ruebarb is offline
Old 09-06-2006, 10:45 AM   #86 (permalink)
ididntdoit5150's Avatar
Member Number: 5242
Send a message via AIM to ididntdoit5150
i might just have to do this, i hope i dont screw it up tho
( O TOYOTA O )
THE FIRST EVER FJC COMMERCIAL!!!!
P.S. - the BD FJC wheelin in the first like 8 seconds with the tinted corner lights.....yeah.....thats me
MY CUSTOM FJC A.K.A. "K.I.T."
ididntdoit5150 is offline
Old 09-18-2006, 01:32 PM   #87 (permalink)
Moderator
opg4759's Avatar
Member Number: 2775
Rue,
Your guide in getting power up through the front of the dash helped me install the remote head for my Yaesu 7800r.
Thanks for the pics they helped a ton.
+1
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount ,Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's, Project Overkill rails,
Gear
Home Brew
Project Overkill
Always trust the Gene Genie
opg4759 is offline
Old 09-18-2006, 06:45 PM   #88 (permalink)
bigbill25's Avatar
Member Number: 1293
We just ALL love Rue's pictures... Yup... Just love 'em... :-P
Old 09-18-2006, 09:54 PM   #89 (permalink)
Moderator
opg4759's Avatar
Member Number: 2775
It's ok BigBill we all love your CB install.
NUFC
Rig
Gear
Home Brew
Project Overkill
opg4759 is offline
Old 10-23-2006, 07:19 PM   #90 (permalink)
Salvor's Avatar
Member Number: 5276
12 Volt Power Outlets
Anyone else have a problem with just one 12 volt power outlet? I figured they would at least put one in the rear. I have the 115 volt unit back there but it would be nice to have a 12 volt too.
Salvor is offline
