Old 12-12-2007, 09:04 PM   #11 (permalink)
TCao's Avatar
Member Number: 940
Re: Lowrence 540c Mounted
Saw Scorpion in person today. The installation of the Lowrance GPS is one of the cleanest I've seen.
2007 Ti FJC
TCao is offline
Old 12-12-2007, 09:24 PM   #12 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
targa88 previously said: View Post
Do you have any close ups of Mike's mounting bracket?
I don't. He shipped it off to me, I received it and the Lowrence was installed without photos. PM him for details. It's very straight forward. The problem with that location is that there's not much to mount to. Not a lot of metal and unless you're willing to bolt through the roof (and I'm not), it's just a bit tricky.
Luckily I had CRUISER LARRY's expertise on this project. The wiring for everything including setting up relays, special fusing, a fuse block, running the wires from the back of the rig, forward, etc. was about an 18 hour job. The fuse block and the lights/GPS are connected to the auxiliary battery. As I mentioned before, the digital LED Quad and the GPS run without the key. The lights require the key to be in the "on" position. I also have the wiring for the Man-a-Fre auxiliary fuel tank in place (done at the same time) so that should go in very easily.
mbisson previously said: View Post
Very nice install Larry.
Thanks.
Thanks TC. I'm looking forward to the new and improved TC machine. I suspect that it's going to end up looking a bit like the AIR2AIR Starship.
uphill is offline
Old 12-12-2007, 10:47 PM   #13 (permalink)
Air2air's Avatar
Member Number: 6928
Whoa! You're getting the MAF aux tank too? Man your rig is outta site. Now we have to keep up with the Lamberts...
Air2air is online now
Old 12-12-2007, 11:57 PM   #14 (permalink)
uphill's Avatar
The Scorpion is never going to be in the class with the StarShip.
uphill is offline
Old 12-13-2007, 12:16 AM   #15 (permalink)
cruiserlarry's Avatar
Member Number: 2011
Wow Larry, after talking on the phone I now see what your talking about on the mount CL made for the Lowrance antenna, very nice! What a clean install he did, I did notice, that you mounted the GPS a little different then I did in regards to the bracket. In your pics it looks like it extends out toward the windshield, is that correct? I may have to try that, hum……Mine as you can see in the pic comes towards the occupants…..I wonder if there is a difference and what it would be. I may have to take my mount down and switch it around and see how it performs. Anyways, the Scorpion is looking very Bad Azz now with the lights, I love it. I can’t wait to hear how you like them tonight. Very nice buddy I’ll see if I can give you some more rep points.
SW, I mounted your bracket in Uphill's rig in a downward direction, as I thought it would position the Lowrance lower and farther back for the driver to see. It looks like you designed it to mount upward to tuck the GPS up higher. Seeing both pics shows how both directions can work well - the bracket is more versatile than you probably thought it would be - nice design.
TLCA #9632
cruiserlarry is offline
Old 12-13-2007, 02:56 AM   #16 (permalink)
Raptor-nator
Shadow-Warrior's Avatar
Member Number: 3913
cruiserlarry previously said: View Post
Great install job Larry, I wished I lived closer and I would have you do mine also. The Antenna bracket is awesome, I think I'm going to have steel your idea myself.
I never thought about a bracket, that I could mount the antenna too, so I don't have to put more holes in the roof. great job buddy. Rep Points to ya.
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Shadow-Warrior is offline
Old 12-13-2007, 03:51 PM   #17 (permalink)
1leglance's Avatar
Member Number: 10073
ok now let's hear some "in use" reports on the lowrance...
1)how easy are inputs in the field if someone hands you a book or paper with numbers?
2) full sunlight screen visibliity? I would think with that high mount you would have great daylight visibility
3) glare/brightness of the screen at night...can you dim/change the color?
4) maps? are you happy with the topo maps, do they show plenty of trails and detail so you can explore?
just some questions since I really like that unit and if I was gonna give up my laptop setup it would be for that.
enjoy,
1leglance
KE7NKP
Disabled Explorers
Helping the handicapped independently access the backcountry
www.disabledexplorers.com
Voodoo Blue driver, night nurse, cigar smoker & all around happy camper
1leglance is online now
Old 12-13-2007, 05:16 PM   #18 (permalink)
jferg's Avatar
Member Number: 3906
Super job!
jferg is offline
Old 12-13-2007, 09:14 PM   #19 (permalink)
Air2air's Avatar
Member Number: 6928
How about a setup where the laptop is kept in the glove compartment, hooked up to the Lowrance so you can keep doing the computer stuff when needed?
Old 12-15-2007, 10:13 AM   #20 (permalink)
Raptor-nator
Member Number: 3913
1leglance previously said: View Post
Ok, I have been running mine for about two weeks now in succession with my laptop running MS Streets & Trips GPS & De Lorme Street Atlas 08 Here are my findings so far.
Lance as far as punching Coordinates it is pretty straight forward. I’m a bit spoiled when it comes to using a laptop GPS system, you just punch in a start point then an end point and it draws a map and route to your destination. I’m still learning the system it is very powerful and will do allot of things for you. They do have a computer hookup you can buy for the BAJA 540c that allows you to use your laptop to make routes real easy then download them on the chip into the GPS unit. I think this is the way to go myself. I’ll be buying the little USB chip plug in from Lowrance.
The screen has four different brightness scales. When you turn the Unit on, it is very bright for daytime driving. All you have to do is hit the power button on the unit one more time and it dims it more, hit it again, and it dims it even more, one more makes it very dim. It works great while driving at night.
The unit comes with a base map of the US but is very basic. I purchased the extra detailed map #F103EX-S of the 10 central US States, this includes the following States. CO, KS, MO, AZ, NM, OK, TX, AR, MS, LA. The map detail is leaps and bounds over the MS & DeLrome products. It gives you actual Topo details, depths of any inland waterways, tiny little creeks, dirt roads, etc. The graphics are pretty cool too. The maps you have to buy extra are about $110. apiece. It’s a little expensive, but well worth the amount of detail that you get. It is kind of funny, I was talking with Larry the other night, and he called and said “Man! Did you know that when you get close to the end of the detailed map chip, it’s like blank!, it just stops. I laughed, and said yeh, I watched when I went to TN leaving just the Eastern side of Memphis I watched the screen change, it reverts back to the base map with very little detail.
So far I love the Unit, again I have only scratched the surface of its capabilities myself. It even has a RADAR function…Hummmm…
That’s my report so far, Larry can chime in here to when he gets back from AZ. I talked with him last night coming back running with Sean K. I understand that the Scorpion went trail riding with two ROCK BUGGIES on a level five trail with huge boulders. He said Sean broke an axe if that tells you anything about the trail he was on. I won’t say anymore, I’ll let Larry give you all the details of the ride.
Todd, that could be alternative, The unit has a cord that comes off it with bare wires so you can hook up a serial port to the end for a computer connection. I plan on doing this myself, that way I can just plug the laptop up load a route to the Unit. I’m sure Larry will have his own report for everyone. Sorry Larry for the hijack of your own thread buddy.
