2007 FJ Cruiser 4x4 Auto TI - Mods too long to list
2007 BMW 335i Black Sapphire - Twin Turbo
2000 Honda Odyssey EX - Navigation
1998 Toyota Sienna XLE - Supercharged
1989 Toyota Pickup - long bed
------------------------------------------ TLCA #17592
Yes, they are cheap and nice.
You also need to buy the plastic (terminal) connector and the 4 splice wires from your local dealer.
or you can solder wires directly to it and shrink wrap. i would just and bullet connectors to the wire so you can remove them when you want. This is another cheap solution.
My real name is "KARLO" so do you get the name "truckhigh"
found this on another thread. here are the pin outs.so , now you have part numbers and pin outs.
Just to be clear, this pinout is for the original switch listed on EBay, not the $13 switch as picture by Oscarr. Oscarr's switch only has 3 connections to the back of it.
So then, does anyone have the pin out for the switch Oscarr pictures (00550-35976)?
Thanks
Decidion (Jeff)
'08 Brick Red
Too many mods to list...
I checked mine from the Honda / Isuzu - it is almost the same but it has a fifth terminal and an LED that lights up when energized - exactly the same size, shape, etc. made by TEC. I think the fifth prong may have something to do with an override - when the high beams were activated the fogs went off.
Thanks
I figured it out....
IPF Lead -> terminal on Taco Rocker Switch (with light on switch UP)
Black -> Top (Ground)
Red -> Middle (Hot)
Black/White -> Bottom (Relay control)
Decidion (Jeff)
'08 Brick Red
jhaydeno, you have any pics of this switch you speak of? or know where they can be seen?
08 Sandstorm | '79 FJ40 Livestrong for Chloe
Residual, take a peek at these pics - If you need more info let me know. I haven't actually stuck it in a toyota hole, but it is exactly the same size and the blank off is the same piece as the toyota switches, atrac, vsc, reverse, etc. I can ohm out pins and map it if anyone wants to try one. Again, this is a TEC switch used in Honda / Isuzu for the last 8 or ten years.
