hey people, tried the search function, didnt come up with much, where did you guys and gals mount your c.b. i just got a new uniden and could use some input and some pics where your c.b. is mounted,thanks
__________________ BLACK CHERRY,ATM ,4 WHD, REAR DIFF LOCK, A-TRAC HACK,TOYOTA HITCH,TOYOTA ROCK RAILS ,CONVENIENCE PKG,BULL BAR, HELLA 500.SIRIUS RADIO,UNIDEN C.B. SCUBA MOD THANKS TO CAPT. RICK AND SLITHER!!!
"HATE IS BAGAGE,LIFE IS TO SHORT TO BE PISSED OFF ALL THE TIME"
I mounted mine on the center console on the passenger side. It's not in the way and it's easy to access.
Check out WalcottCB.com. Type Big Bill in the search box. Once it opens click on it and you will find a great install. I purchased all the stuff except the CB as I had my own too. It all mounts up very easy and I highly recommend the Bandi mount. Sweet stuff....hope this helps.
Mounted My big ol' Uniden PC78 to the passenger glove box, without preventing the passenger seat to slide all the way forward to get to the back seats easily.
Here's a post that I stumbled on when I was trying to figure out the same thing:
thanks my uniden is larger and heavier then i expected it to be
I did the same as Steve did above. Works well. I have been kicking around the idea of mounting it on the ceiling just aft of the aftermarket dome/map light I mounted up front. Weight has me nervous though...
-Matt
2007 AT 4x4 Voodoo Blue FJ, ARB Bumper, Tabor 9K winch, IPF lights,
ProComp 87 Black Steelies, Nitto Terra Grappler 305/70-16, OEM rock
rails, ToyTec 3" Lift w/ OME 885 springs and ProComp rear shocks,
AVN5500 Nav, Dome/Map lights, Mirror turn signals, HomeLink, Uniden
PC68XL CB, Painless dual-battery, aux camp lighting, bottle opener,
and MUCH trail pin-striping
I have one of those real small midland cb radios, and i mounted mine inside the little box ou have it mounted to, just drilled a hole big enough in the bottom of it to run up power wires and pl259 connector to radio this works well for me, because i have rear seat passengers very often..
thanks for info people, might go with glove box mount
07 Sun Fusion
A/T, Roof rack, Conv. package
ATRAC, Rear diff lock
3" Toyotec lift, OME 884's up front
& Toytec customs with OME shocks out back
BFG KM2's 285/70/17
Factory steelies
Scuba mod
AFE CAI
AFE 3" High clearance exhaust
All Pro Sliders
Tundra door handles
Cobra 75 WXST CB, Bandi mount & 3' Firestick
48" Hi-Lift jack
Yellow IMP shifter knobs
Garmin c550 GPS with FJC icon
