Old 02-11-2008, 04:38 PM   #1 (permalink)
S2bear's Avatar
Member Number: 9648
Send a message via Skype™ to S2bear
DRLs fire up Aux lights
I installed 2 sets of aux lights on my roof bar and used two relays, one for each pair, linked into one OEM light switch. Originally I took the Switch feed direct to the battery and this allowed me to turn the lights on and off at will - regardless of any lights or the ignition being on. ALL WAS FINE - NO PROBLEMS. I decided though, that I wanted to ONLY be able to turn on the lights when the Hi Beams were on so I tapped the switch feed into the Hi Beam fuse in the main fusebox under the hood. everything is still fine and I have a choice - I can leave the switch in the ON position and the aux lights only fire up when I flash my Hi Beams, or I can leave the switch in the OFF position and just flash the OEM Hi Beams. HOWEVER, if I leave the switch in the ON position, when I start up the FJ and the DRL's light up, they fire up the Aux lights too, (without the hibeams on). I can either Flash the hi beams or push the switch to OFF to turn off the Aux lights - just as I normally would.
Q: Anyone know why they're firing up with the DRLs?
Apologies in advance for this rambling question. Stu
Never interrupt your enemy whilst he's making a mistake - Napoleon Bonaparte
Diamond Black, PKG2, Auto 4wd
AR Teflon Chamber 17x9 & 285/70 17 Cooper STT
Body mount chop
TRD CAI
Light bar & 6xKC slimlites (2pencil, 4driving)
Gobi Ladder, Yakima FatCat6
Dice box
12v drivers glovebox
Donahoe Coilovers in box, in living room.... in trouble... (not installed yet)
S2bear is offline
Old 02-11-2008, 05:30 PM   #2 (permalink)
04e46conv's Avatar
Member Number: 13320
Re: DRLs fire up Aux lights
Sounds like a good idea now you got me thinking about doing it.... but I am thinking that it has to do with where to you taped..
I would wire them so the switch with turn them on and off when ever you want like to had it at firs then run another line from the him beam to the relays to trigger the aux lights...
I think I am going to look in to this...
-Loaded 6MT
Mods-
-2 Hella Rally 4000 Fogs on Brush Bar 100w yellow fog bulbs
-2 Hella Rally 4000 Compacts Driving Beam on Manik Light bar
-2 Hella Rally 4000 Compacts Pencil Beam on Manik Light bar
-Hella FF75 Fog Kit (rear underside roof rack)
-Manik Rear Tail Guards
-4 OEM Toyota FJ Aux Fog Switches
-Dirty Parts Dual Battery Kit
-4 Extra Cross Bars W/ Thule Ski Rack
-Fourtreks Hi-Jack Mount
-Pioneer Avic D3 XM Traffic Nav Bluetooth Ipod
-Heated Mirrors
04e46conv is offline
Old 02-12-2008, 08:42 AM   #3 (permalink)
S2bear's Avatar
Member Number: 9648
Sounds like a good idea - i just can't understand what's making the DRLs trigger the Aux lights on startup. it's bizarre.
Body mount chop
TRD CAI
Dice box
S2bear is offline
Old 02-12-2008, 10:31 AM   #4 (permalink)
k44
k44's Avatar
Member Number: 14041
I think that on all vehicles with headlight DRL's, they use the high beam filaments, with the voltage reduced to 85% of normal. So you're relays are only seeing 11 volts but that's enough to switch them.
--Mike
'07 SunFusion 6MT
k44 is offline
Old 02-12-2008, 11:41 AM   #5 (permalink)
Member Number: 3024
Yes, the DRLs are your high beams at lower wattage. You might not be able to make that happen unless you disconnect the harness that controls your DRLs. With that disconnected, it should work the way you want it to.
sunfusion07 is offline
Old 02-12-2008, 03:47 PM   #6 (permalink)
FJKoji's Avatar
Member Number: 13609
If you use a blank fuse spot in the stock harness you should be able to run the aux lights when you want except when the vehicle is off. That might be an easier solution than trying to tap the hi beams? Just my .02
'08 Off Road Pkg. MT
TRD CAI|JBA CatBack Exhaust|TBS|All-Pro AirDam w/ PIAA 540s & Soletech Spots
Alpine IVA-W205|Blackbird II Navigation|Bluetooth Interface|Alpine MRP-450 Amp|Infinty 10" Sub| Infinity Reference 3.5"
Next to Get: Sliders, Bumper
FJKoji is offline
Old 02-12-2008, 09:02 PM   #7 (permalink)
Member Number: 3024
I say disconnect the DRLs and see what that does.
Old 02-12-2008, 10:25 PM   #8 (permalink)
5Greens's Avatar
Member Number: 6542
Where do you pick up the ground for the relay?
2007 -VOODOO 4x4 AT, CQ, GY, RB, UR, 5A, Z2, C7, LOJACK
Mods Listed at AFJ4x4.COM
5Greens is offline
Old 02-12-2008, 10:29 PM   #9 (permalink)
cruiserlarry's Avatar
Member Number: 2011
S2bear previously said: View Post
You should tap the high beam take-off from the hi-beam power wire before the DRL circuit out by the headlights...
TLCA #9632
cruiserlarry is offline
Old 02-15-2008, 08:45 AM   #10 (permalink)
S2bear's Avatar
Member Number: 9648
Thanks for the solutions guys - that's my weekend sorted then!
What colour's the live wire on the high beam? (being lazy as I am) Stu
Body mount chop
TRD CAI
Dice box
S2bear is offline
