Old 02-17-2008, 05:10 PM   #1 (permalink)
ThyIrishMen's Avatar
Member Number: 16077
how to make stock subwoofer work with headunit?
i have my head unit all hooked up *alipine xi001. and everything works great except for my subwoofer now does not work with it. how do i get this to work?
[2006 Yamaha R6]
[2008 Trail Team Edition]
Tiochfaidh Ár
[The first member to rock the Trail teams]
ThyIrishMen is offline
Old 02-17-2008, 05:37 PM   #2 (permalink)
toyotaoffroadFJ's Avatar
Member Number: 13561
Re: how to make stock subwoofer work with headunit?
splice the remote wire withe the pink blue stripe wire that goes the the subwoofer switch...
toyotaoffroadFJ is offline
Old 02-17-2008, 05:44 PM   #3 (permalink)
crestwood36's Avatar
Member Number: 17104
Send a message via AIM to crestwood36
Here's a breakdown of the wires going into the sub. Make sure these wires are properly hooked up at your headunit. Because I'm a techie, I'm going to ask a dumb question. Is the subwoofer button switched to on? Sometimes the easiest things are the ones we miss.
"The ultimate goal of the educational system is to shift to the individual the burden of pursing his own education. This will not be a widely shared pursuit until we get over our odd conviction that education is what goes on in school buildings and nowhere else."
John W. Gardner
crestwood36 is offline
Old 02-17-2008, 06:17 PM   #4 (permalink)
i have the crutchfield wire harness wired up to my alpine harness. so i pluged them in and thats it. yes my sub button was on. so i take the wire from the button thats pink and run it to my pink and blue wire on my alpine harness? or do you mean i have to do the wires up in your diagram wired up to my alpine unit as well as the normal speaker wires, almost as if their was two sets of each?
[2006 Yamaha R6]
Tiochfaidh Ár
Old 02-17-2008, 06:20 PM   #5 (permalink)
thugasaur's Avatar
Member Number: 691
Send a message via AIM to thugasaur Send a message via Yahoo to thugasaur
i told my kenwood that it was a 7x10 speaker and cranked up the through put and that little sub bumps enough my girlfriend complains its too much bass , i also turned up the WoW settings so it pushes more bass to the rear
Chefj's Little known facts: Thugasaur tracked down, strangled, and gutted the Snuggle fabric softener bear because he once had a towel that was...well...not so soft.
UBFM member #00 enforcer
"Church" V2.0
2007 Voodoo 5AT 4x4
______________________
AFE cai , kenwood excelon 889 , xm2go, piaa extreme super whites , demello front skid plate and rock rails and aero flow lens covers (THANKS GUYS!) , all-pro front sway bar links
thugasaur is offline
Old 02-17-2008, 06:30 PM   #6 (permalink)
As far as I know, the sub is being fed by the Right Rear and Left Rear lines from your head unit. First thing I would do would be to turn the fade all the way to the rear so only your rear speakers and the sub should be firing. If there is nothing going on back there, then I would check the harness. It wouldn't be the first time I saw a Crutchfield harness that was mislabeled. When I had my Crossfire, a few of the wires were flipped.
John W. Gardner
Old 02-17-2008, 06:55 PM   #7 (permalink)
I dont have anything wired up to the wires going to the sub switch, and plus their was three harness's unpluged from my stock headunit, but i only have 2 connected back up for my alpine. I dont no what the third is, or what i would do with it.
[2006 Yamaha R6]
Tiochfaidh Ár
Old 02-17-2008, 08:43 PM   #8 (permalink)
just splice the remote wire on your deck to the pink with blue stripe wire that goes to the switch...you have to complete the circuit...2 minuteds and its done
Old 02-17-2008, 08:49 PM   #9 (permalink)
splice it so that all three are connected? so that it still goes to the button , but also to my headunit.
[2006 Yamaha R6]
Tiochfaidh Ár
Old 02-17-2008, 09:49 PM   #10 (permalink)
Singha's Avatar
Member Number: 12233
The third plug is for the steering radio control of the radio.
Problem I recently had was the
factory harness adapter To radio harness (Kenwood)
was calling for POWER Antenna from the radio. I know the Fj DOES NOT have a power antenna. But I did it anyway. So the sub would only would work on RADIO mode and nothing else. I went back and swap it with AMP remote to stock harness adapter. Work great now.
TLCA#18914
GCLC#2083
NYC
Ti 6sp. CQ GY UP C7 37 2Q.
ADDED 6D(x2),EL,V5,WL(x2).
SE Speced PLUS/TRD CAI,Q/Shift,Raditor Cap,JDM TRD gas cap cover.
MODS
AllPro Sliders,E-Locker+Diff skid,R-LCA,Bandi,Digger R-UCA,OME 883+TP14(w/TRDs),Rear OME 895E(w/TRDs),Rasta Skid plates,TC A-Arm Skids,Lucrum mount WO/winch.
Hella horns,Husky mats,SGII,Osram SilverStar,OEM Brush Guard w/Hella 500FF,LightBar w/ 4 Hella FF50,
Dave Crums NEW Rear Trailing Arm MOUNT. Amsoil Gears Oil.
Singha is offline
