Old 02-20-2008, 12:56 AM   #1 (permalink)
jdllizard's Avatar
Member Number: 12818
How can I get more from my FJammer?
I didn't get the optional sub, and now I want more from my stereo without ditching the FJammer and starting over. Any suggestions as to what to do. Add an amp and sub? Who else has done this and how did it work for ya?
I just want to add to the factory stereo so I can get better sound, higher volume, better bass, and not risk blowing the exsisting speakers. Maybe it's just a pipe dream and can't be done, but I'd like to hear what the hive mind has to say about it.
TIA.
JD
jdllizard is offline
Old 02-20-2008, 01:02 AM   #2 (permalink)
Briman42487's Avatar
Member Number: 7204
Re: How can I get more from my FJammer?
i would start by replacing all of the speakers. front with a set of componets (mid in door, tweet in factory dash location) and a rear set of coaxial in a pod. forget about the factory rears. get an amplifier for them. and to use the factory deck you are going to need a line output converter.
from there you can add on a woofer and bass amp.
i would highly recommend going that route. it will cost a little more, but once you take that first step in the right direction, you wont have to spend more money making it right in the long run.
Briman42487 is offline
Old 02-20-2008, 05:30 AM   #3 (permalink)
shane4x4's Avatar
Member Number: 5342
Also get some Dynamat or similar product. We used dynamat in the doors when we replaced the front speakers, it's helped out quite a bit. We didn't add an amp, but upgraded the speakers & the sound is much clearer, but not much louder.
'07 TRD w/3" Toytec, Ellis Precision grab handles, WAAG XS Rack Insert, Over The Top HDPE Skids, TinCan's Red LED Dash
TLCA#18775
Lead Run Planner: http://15ers4x4.com | Webservant: http://coloradofjs.com | Off-Road Trails Wiki: http://www.dirtopia.com
KC0KWO on 2m @ 146.520mHZ
http://www.fjc-mag.com | July Issue: http://fjc-mag.com/july-2008/july-20...issue-3-2.html
2008 Stanley Cup Champion DETROIT RED WINGS!
shane4x4 is offline
Old 02-20-2008, 05:55 AM   #4 (permalink)
RomaBoy's Avatar
Member Number: 2866
jdllizard previously said: View Post
TIA.
JD
Sounds like you don't have the 9 speaker factory setup with the sub so I would say install a sub woofer and that would cover the bass end. I have the 9 speaker system and I'm happy with it.
RomaBoy is offline
Old 02-20-2008, 07:39 AM   #5 (permalink)
Ishq's Avatar
Member Number: 9259
Send a message via MSN to Ishq Send a message via Yahoo to Ishq
All the advice to replace speakers and so forth is a waste of money. Remember replacing speakers also means adding costly spacers. The FJammer is simply under powered. The OE speakers are good quality and fine for 90% of stereophiles. Amplifying the unit will be the best place to start. The clarity and volume will be vastly improved.
~Ishq
-- Muy Burro Con Letch! --
2007 Toyota FJ Cruiser TRD 4WD Auto. Loaded and then some.
Ishq is offline
Old 02-20-2008, 07:48 AM   #6 (permalink)
codymurfy's Avatar
Member Number: 17351
I like realy loud music, and the fjammer and 9 speaker setup has worked great for me. I did put in 2 12"kicker cvr subs, but they took u wayy to much space. So I had a local shop build me a very narrow wedge for one, that sits in the back. I had to modify it a little because it was not deep enough. I still have my same amp, so I definitely get enough bass out of it. I will post pics if I can remember
Its an FJ thing!
TLCA:18474
Check Out my build in progress:http://www.fjcruiserforums.com/forum...tml#post848167
codymurfy is offline
Old 02-20-2008, 10:20 AM   #7 (permalink)
ThyIrishMen's Avatar
Member Number: 16077
but the magnet on the front speakers is like the size of a dang peanut! compared to the rest of itself.
[2006 Yamaha R6]
[2008 Trail Team Edition]
Tiochfaidh Ár
[The first member to rock the Trail teams]
ThyIrishMen is offline
Old 02-20-2008, 10:27 AM   #8 (permalink)
Ishq's Avatar
Member Number: 9259
Magnet has little to do with it. Consider high end Bose speakers for example... tiny. The FJammer radio is simply under powered. Amplify what you have first then go from there. You'll thank me later for saving you wasted money and time on new speakers.
~Ishq
Ishq is offline
Old 02-20-2008, 10:35 AM   #9 (permalink)
mungk's Avatar
Member Number: 5043
how do you amplify stock speakers? Do you need to buy diy crossovers etc?
www.fjbruisers.org
"Give me a museum and I will fill it." - Picasso
mungk is offline
Old 02-20-2008, 10:43 AM   #10 (permalink)
Ishq's Avatar
Member Number: 9259
The easiest thing to do is roll over to your favorite car audio store and then let them do it.
To do it yourself, you'll need to find the wiring schematic to find your way around all the radio wire spaghetti.
This kind fellow has them here: Toyota FJ Cruiser: Resources & Documentation Archive
~Ishq
Ishq is offline
