Just bought a ScanGauge-II I'm unable to get it to communicate to with the cars computer. When I have it physically connected to the ODB port, the device just displays "CONNECTING" and then turns off. At the same time, a bunch of my dash lights come on.
I'm guessing my ScanGauge is DOA, but just in case I thought I would post a message here.
UPDATE: Just got off the phone with the great folks at Linear Logic, and they are sending out a new unit and a shipper so I can send them the broken one. They admitted that a bad batch of scan gauges that had a "bad crystal".
UPDATE 2: Got my replacement unit yesterday and it works just fine.
Just bought a ScanGauge-II I'm unable to get it to communicate to with the cars computer. When I have it physically connected to the ODB port, the device just displayes "CONNECTING" and then turns off. At the same time, a bunch of my dash lights come on.
Plug it in then start the truck. it turns off automaticly if the trucks not running or if you are not activly pushing buttons.
__________________ Ligten up, it's the internet!
air previously said:
Quote from: BigDouggieDoug
Location: Oh mommy I ain't no commie I'm just doing what I can to live the good all American...Way
Re: Scangauge-II Install not working
I just sent a message and asked about it.. here's the response.. Ron
Ron,
The ScanGauge should work on the FJ Cruiser just fine. The different cable that is used is to address an issue with a small number of cars that use certain pins on the OBDII port that interfere with the operation of the ScanGauge and the vehicle. The typical symptom is the clock radio is reset when the ScanGauge is plugged in or if the speedometer fluctuates randomly with the ScanGauge plugged in. If you experience any of these problems, or anything odd while the ScanGauge is plugged in just let us know and we will get a modified cable out to you.
James DeLong
Linear Logic LLC
Operations Manager
spankbot previously said:
Can you elaborate on what you mean by this? Wrong line?
I plan on calling Linear Logic tomorrow.
Assuming the ScanGauge II has a problem, Linear Logic warranties their products for 1 year - if you think it's bad, call them 888-433-5664.
Guess I'll have to do that. My buddy has a Scanguage on his FJ and his works perfectly, so we tried plugging mine into his...just kept saying connecting. I ordered another one a week ago and it does the same thing, I believe Scanguage shipped out a bad batch...
