Old 05-03-2008, 09:16 PM   #1 (permalink)
MinnesotaFJ's Avatar
Member Number: 13576
400 watt inverter safe for laptops??
Can I safely charge/use my laptop with the 400 watt inverter?
MinnesotaFJ is offline
Old 05-03-2008, 09:24 PM   #2 (permalink)
SwiCago's Avatar
Member Number: 15488
Re: 400 watt inverter safe for laptops??
I say yes, since the laptop will be using a brick(power adapter) to get its DC votage(most likely 19V)...The brick will clean any impurities caused by the inverter. Second, 400W is more then plenty for the laptop, so enough power isn't an issue,
Cheers
AL
SwiCago is offline
Old 05-03-2008, 09:52 PM   #3 (permalink)
Air2air's Avatar
Member Number: 6928
Minnesota, 400W means that's how much the inverter can supply if the device requires it. Not what you're thinking...
Air2air is offline
