» Tire Upgrade Garage
Old 05-07-2008, 10:16 AM   #11 (permalink)
Teejeaux's Avatar
Member Number: 4914
Send a message via MSN to Teejeaux
Re: Where should I mount my HAM?
Mikey D. previously said: View Post
You'll have to excuse me, I have a ICOM 207H - the head and mic are separate so mounting with Velcro wasn't a problem for me!
Mike
Ahh, yeah, if that was the case, it would be easy. I've got LOTS of places I could mount it if I didn't have to worry about the cord of the Mic hanging in my way.
Thanks!
Teejeaux
N7TJO
Life's journey is not to arrive safely at the grave, in a well preserved body;
But rather to skid in sideways, totally worn out, shouting, ... Holy Sh*t!! What a ride!!...
Teejeaux is offline
Old 05-07-2008, 10:24 AM   #12 (permalink)
MountainMan's Avatar
Member Number: 8491
i have a 2.5" x 2.5" piece of heavy duty velcro on that little angled spot right in front of the eBrake where i stick my HT - if you get good quality heavy duty velcro it works good, grabs hard.
MountainMan Johnson (blog) WØOZY MEMBER: FJ Cruiser Club : NRA : BSA : ARES
Mods: Tint : ClearPlex : Shovel & Axe w/ FourTrex Mount : M-Pac Storage : Blackened Trim : Bandi Mount : Diamond NR770 Antenna : Yaesu VX-7R : Yakima PowderHound : DeMello Round Sliders : DRing Hitch : Recovery Strap : Next_Cooper STT's
MountainMan is offline
Old 05-07-2008, 10:43 AM   #13 (permalink)
opg4759's Avatar
Member Number: 2775
I used a suction mount to this windshield. I like this method since it's non-destructive.
7800 install
NUFC
Rig
Black Diamond M/T,Custom XM Inno mount ,Bandi antenna mount/ Yaesu FT-7800r, 4 Piece Budbuilt Skids(still need the gas tank skid), OME 886/895, All-Pro upper and lower links, Procomp 7089, Procomp Extreme M/T's
Gear
10lb Powertank, fourtreks Hi-lift mount, ARB X-Jack,Curry E-Z Tire Deflator
opg4759 is offline
Old 05-07-2008, 10:49 AM   #14 (permalink)
Teejeaux's Avatar
Member Number: 4914
opg4759 previously said: View Post
7800 install
What's the name of that mount? Where'd you get it?
Thanks!
Teejeaux
N7TJO
Teejeaux is offline
Old 05-07-2008, 11:04 AM   #15 (permalink)
frogeye's Avatar
Member Number: 6849
Teejeaux previously said: View Post
I like that! Frogeye, what did you use to mount that there? Just drill through the plastic? How solid is it? Does the mic cable get in the way?
All I did was drill two tiny holes and used the supplied nuts and bolts for the plate. It's very solid. The mic cable stays off to the left and isn't in my way.
Chris | My FJ El Froggo | My Austin Healey Frogeye Sprite
frogeye is offline
Old 05-07-2008, 11:07 AM   #16 (permalink)
OlyWaFJ's Avatar
Member Number: 3762
Talking Re: Where should I mount my HAM?
Mounting capabilities and location is why I went with the ICOM-208H.
I've cleaned up the cabling since this photo was taken...
The Yaesu's mic has to connect to the remote head which is problematic for cable management. All the Icom's go back the radio which allows for a really clean install.
I put the external speaker under the rear seat on the drivers side facing forward, no photo but works very well.
President - TLCA South Sound Cruisers
2007 BC, 4x4 AT,Rear Locker, A-Trac, Terra Grapplers, BudBuilt Skids, Stubbs Sliders,
OME Med/Med, ARB Bull Bar, IPF Fog lights, ICom IC-208H 2M/440
TLCA# 16640
OlyWaFJ is offline
Old 05-07-2008, 11:14 AM   #17 (permalink)
opg4759's Avatar
Member Number: 2775
It's a metra universal gooseneck mount.
I got it at Circuit City
The trick is mount it low and then I also put rubber feet on the bottom of the radio face and the mount plate so it wouldn't rub on the dash. I've used this setup since I installed the radio and have been nothing but happy with it.
The only change I'm going the be making is I'm going to remote the mic to the center console.
Also if you haven't bought the remote kit yet, don't. You can order the nesting plate for the face for 5 bucks from the Yeasu parts department(i will look for the phone number, and the remote cable can be built with cat 5 and 2 6 pin RJ-25 connectors. I built my own remote mount kit for 30 buck with the mount. This would no different with a 8800 or 8900
NUFC
Rig
Gear
opg4759 is offline
Old 05-07-2008, 01:57 PM   #18 (permalink)
Teejeaux's Avatar
Member Number: 4914
The remote kit came with the radio. Hamcity has them for $350 including the remote kit. I like the 8800 because it has the dual monitoring capability on a dual band radio.
Thanks!
Teejeaux
N7TJO
Teejeaux is offline
Old 05-08-2008, 07:06 PM   #19 (permalink)
Member Number: 19645
I have a question... are any of you using more then the Bandi mount for your antennas?
I have a ICOM 706... i need to mount two antennas... one for HF, on the Bandi mount.. I have a outback Perth Plus to go there... but i need a VHF antenna... is anyone mounting besides the rear bandi mount?
Is anyone trying a hood mount?
I actualy have a use for possiably a second VHF antenna.. I am involved with my township ema... help me out here guys.. i am sure i am not the only one with the need for two antennas..
Thanks
Chris
WZ3Q
Polar_Rescue is offline
Old 05-08-2008, 07:25 PM   #20 (permalink)
frogeye's Avatar
Member Number: 6849
Check out FJ Ollie's BugEater in the Members' rigs section of this forum. He's got bookoo antennas.
Polar_Rescue previously said: View Post
Thanks
Chris
WZ3Q
frogeye is offline
