Problem! If you ran wires in the door sill.
If you ran wires under the driver side door sill plastic check them.
Mine where cut threw and shorting out.
There are a set of empty white plastic clips that look perfect to run some new wires
from front to back, don't use them. When the plastic door sill goes back on
it will cut the wire in three places.
If you did the same thing and haven't had a problem yet maybe check them before it is a problem.
2007 Voodoo Blue FJ
SkyJacker Platinum series 3" lift suspension, AllPro Front & Back bumpers, Hankook 285/70/17, SpiderTrak 1.5" wheel spacers, Total Chaos front upper CA's, AllPro rear lower CA's, no rear sway bar, front sway bar moved forward .5", IPF / Piaa lights, Gobi Stealth roof rack, URD super charger, JBA headers, URD Y pipe, FlowMaster muffler, AllPro high clearance tail pipe with custom end.
AllPro skid plates, factory rock rails, CB, Bandi mount, XM Radio, Garmin GPS, Side sun visors, modified shifter, trans valve body mod.
