Old 05-19-2008, 09:04 AM   #11 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Re: Hardwired Cobra, TomTom One LE
FJ FunJunkie previously said: View Post
I'd suggest one thing to make it cleaner on the tomtom. you can pop the silver vent thing off by pulling it forward then pop the speaker cover and you can run the wire only showing about 2 inches right at the base of the windshield.
Better yet, you could remove the A-pillar cover to hide both wires (to the Tom-Tom and Cobra).
DASH, CONSOLE & DOOR PANELS REMOVAL: Instructions w/ pics
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is online now
Old 05-19-2008, 09:53 AM   #12 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
also an excellent suggestion.
Ligten up, it's the internet!
Quote from: BigDouggieDoug
You Should Help Chris Walk
FJ FunJunkie is online now
Old 05-19-2008, 11:15 PM   #13 (permalink)
Has He Lost His Mind?'s Avatar
Member Number: 4663
Understood. Yes, the DC adapter's fuse will protect your GPS and radar detector. However, I was referring to the power source (wiring) itself coming from the fuse panel to your DC adapter.
If there's no protection there and a short-circuit occurs between the fuse panel and the DC adapter, the DC adapter's fuse won't protect the rest of your FJ's downstream electrical system from severe damage and/or possible fire.
Just a suggestion . . . .
Ahh, I see what you mean. I'll definitely do that this weekend.
Louis An Photography:
2007 Sun Fusion 4X4 AT, Big Foot A/T, Two 10 inch Alpine Type-E, Alpine M500 Amp
Colorado
Has He Lost His Mind? is offline
Old 05-23-2008, 08:13 AM   #14 (permalink)
Crimlaw's Avatar
Member Number: 16567
Question = can I do the following:
1) cut my tom tom power cord before the cig adapter
2) attach tom tom cig cord (that i cut) to Add-A-Circuit
3) plug in Add-A-Circuit plug to fuse panel
I'm not good with electrical work at all so just wondering if anyone can lend a hand before i start chopping wires.
Crimlaw is offline
Old 05-23-2008, 11:26 AM   #15 (permalink)
Crimlaw's Avatar
little bump
Crimlaw is offline
Old 05-24-2008, 01:03 PM   #16 (permalink)
Member Number: 8627
Crimlaw previously said: View Post
Yes to all. Matter of fact, if you choose to do so (which I would recommend), connect your Add-A-Circuit to a "switched" circuit on your fuse panel so that your Tom-Tom automatically turns off and on with the ignition (to prevent accidental battery drain).
This particular fuse slot is not only "switched," but it's also not being used by any other component in the FJ.
Just be mindful of your power cord's polarity (+ and -), and be sure to ground the negative (-) side. Use the manufacturer's recommended fuse size in the Add-A-Circuit. And, use quality automotive electrical crimp connectors.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 05-25-2008, 12:53 PM   #17 (permalink)
Crimlaw's Avatar
Thank you very much! As for the "switched" slot how would I know which fuse slot is switched? Is there an online diagram? Thanks again!
Crimlaw is offline
Old 05-25-2008, 09:12 PM   #18 (permalink)
Member Number: 8627
As shown in the above diagram, the 5th from the left (middle row) just happens to be an empty "switched" fused slot.
I didn't happen to write them all down as I checked them previously. But, with the engine turned off, you can use a continuity light (or a VOM) to check each open slot for power. Anything that lights up is "un-switched" (with the ignition turned off). Whatever remains will be your "switched" fuse slots (which require the ignition to be ON).
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 05-25-2008, 09:19 PM   #19 (permalink)
mtnkraut's Avatar
Member Number: 15139
Steve 2 dummy questions. i got an add a fuse to hook up my CB. which of 2 slots do i put the fuse into? and also the fuse does not want to go in past the wedge on the prong. is it supposed to go hard and how do i get it in? flame away.
EDIT
Nevermind, i figured it out
FJ- Blue
mtnkraut is offline
Old 05-25-2008, 09:22 PM   #20 (permalink)
VooDude's Avatar
Member Number: 14197
x3 or however many more suggested it!
"JULIET" is my '07 VooDoo Blue 6MT Hybrid (Gas/Air) /Black Steelies TLCA#17788 / OME 886/895
GIBSON Exhaust / ARB Sliders / AP Bumper & Skid / Warn 9.5xp / Viking line & fairlead
AVIC-D3 / Viper / Alpine PDX-5 / Type R 6.5 Comp / Type R 6.5 Coax in PODS / WickedCAS w/ 2 10w1v2's
"60 percent of the time, it works every time."--Sex Panther Cologne
VooDude is offline
