Old 09-23-2008, 02:03 PM   #1 (permalink)
BigBlu's Avatar
Member Number: 18013
Aftermarket Power Inverter
I'm looking for recommendations on aftermarket power inverters. I saw a few in the search function but not anything that was too recent. Anybody install an after market inverter?
Thanks
BigBlu is offline
Old 09-23-2008, 02:08 PM   #2 (permalink)
Fjamming's Avatar
Member Number: 6623
Re: Aftermarket Power Inverter
If I were to get one, it'll be the Xantrex™ XPower™ Inverter 1000 - 120 VAC/60 Hz from Costco. Great warranty and priced right. Have not used one, but this one looks good on paper plus it's easy to return Costco items if I don't like it.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 09-23-2008, 04:35 PM   #3 (permalink)
BigBlu's Avatar
That one looks good! Thanks
BigBlu is offline
Old 09-23-2008, 05:03 PM   #4 (permalink)
Savvyav's Avatar
Member Number: 2188
Got two of these and the remote switch...fans, usb 5v out....works perfect.
Cobra CPI 2575 2500-Watt 12-Volt DC to 120-Volt AC Power Inverter
AKA Thread Killer I post and bore threads to DEATH. Ninja poster, like I was never there.....
The Flying Pig BD, MT
Mods: REALLY nice tire stem covers
Savvyav is offline
Old 09-23-2008, 05:05 PM   #5 (permalink)
Savvyav's Avatar
Member Number: 2188
Remote switch is perfectly flat and hides away. Needs a bit of modification.
Savvyav is offline
Old 09-24-2008, 09:00 AM   #6 (permalink)
Member Number: 20723
I have used Xantrex products and can vouch for their quality. I prefer the slightly more expensive versions of their line under the "ProSine" label. They provide true sine-wave power which if you run sound equipment, computer equipment, or any other sensitive electronic gear, is your best choice. Normal inverters use a stepped modified sine-wave which makes some electronics buzz or work erratically.
Howls,
FJ Wolf
Wolf is offline
Old 09-24-2008, 09:10 AM   #7 (permalink)
MrBigAxe's Avatar
Member Number: 12016
Wow, that ProSine costs as much as an Icon stage 1 lift... plus a set of Camburg UCA. Of course, getting a real sine wave out of an inverter requires FM (F'ing Magic), and magic ain't cheap.
2008 Sandstorm, AT, CQ, OF, Roof Rack, TG Sliders, 6 Circuit Accessory Fuse Box, Tacoma Fog Light Switches, SilverStar Ultras, Titan Air Jack, After-Market Power Inverter, Trail Team Badge, M-PAC Rear Door & Side Rack Combos, #10 CO2 Tank, aFe TBS CAI & Hi Tuck Exhaust, Icon Stage 1 Lift, Camburg UCA.
http://www.4X4mayhem.com/register.php?REF=271
MrBigAxe is offline
Old 09-24-2008, 10:18 AM   #8 (permalink)
StHarris's Avatar
Member Number: 4633
Send a message via AIM to StHarris Send a message via Yahoo to StHarris
The Cobra Cobra CPI 2575 with remote on/off looks pretty cool. Would be a good addition to the factory inverter.
07 Sun Fusion
TLCA # 16633
StHarris is offline
Old 09-24-2008, 10:45 AM   #9 (permalink)
StHarris's Avatar
Member Number: 4633
FJ Wolf previously said: View Post
Howls,
FJ Wolf
Xantrex ProSine are great units, but a little overkill for standard vehicle use (unless you are running an emergency vehicle or RV). I have seen these used alot in home configurations for backup.
07 Sun Fusion
TLCA # 16633
StHarris is offline
Old 09-24-2008, 12:45 PM   #10 (permalink)
Savvyav's Avatar
Member Number: 2188
Modified sinewave, pure sine wave...blah blah blah...unless you are running a mobile command station with electronics than of course, spend the extra cash for the smooth power. Most items, if either converted to 12dc or simple ac motors (hairdryer, fridge, etc) go modified! Just make sure to take into account peak vs regular ol running output power. Most small converters won't readily output for long as heat and conversion breaks down quickly. consider what you will be using it for most and how often and go from there.
Dang techie snobs
Savvyav is offline
