Old 07-18-2006, 03:08 PM   #1 (permalink)
Member Number: 1883
Need help with amp install
Installing a new amp. Looking for wiring diagram to pick up high level inputs(using stock HU) from stock subwoofer wiring harness for line converter. there used to be a post on here that had a diagram but the "search" function turns up nothing helpful. Also tips on panel removal for running my power to the battery would help. Thanks ya'll.
Dr. Buzz is offline
Old 07-18-2006, 03:31 PM   #2 (permalink)
chris2's Avatar
Member Number: 2343
Re: Need help with amp install
Not sure if this will help lots of info. http://brockandbecca.com/files/fj/
chris2 is offline
Old 07-18-2006, 07:47 PM   #3 (permalink)
Member Number: 1883
thanks, that pdf has a diagram of all the leads I needed to tap. 2 - 10" Punch Stage 1's and 300.1 Punch Amp (300watts RMS) Sounds Awesome.
Dr. Buzz is offline
Old 07-19-2006, 01:49 AM   #4 (permalink)
rhettdog's Avatar
Member Number: 1488
you can't post stuff like this without pics
rhettdog is offline
