Old 04-22-2007, 09:34 AM   #131 (permalink)
CactusJK's Avatar
Member Number: 1157
Re: Cobra 75 WXST and Bandi Mount Install
What is that wire hanging down, a ground? What are your SWR readings? Interested to see what others have done to maximize xmit with the Cobra 75.
CactusJK is offline
Old 04-22-2007, 09:57 AM   #132 (permalink)
Wonkinator's Avatar
Member Number: 4262
Just got mine done! Perfect directions. The only problem I had was getting the SWR set, plus I don't like that rubber grommet that holds the piece that connects to the handheld. Wish it had a stronger (bolt in) bracket, to hold it tighter.
My SWR readings were about 1.4. I really had to crank down on the antennae (where it connects to the bandi mount) to get it out of the red zone.
Thanks BigBill and Bandi!
Wonkinator
07 FJ Titanium, 4x4, auto, ToyTec lift
Wonkinator is offline
Old 04-23-2007, 04:17 PM   #133 (permalink)
TJ Cruiser's Avatar
Member Number: 3134
I thought of this today as I was looking at the antenna top. Is that top plastic cap gonna pull off if you drive under branches and whatever????? Anyone lose theirs yet? Should we glue them on or use black duct tape?
Ideas..........
Black Diamond FJC 4x4 AT Loaded. Revtec 3" Lift, Tires-33 x 12.5 R 20 TOYO Open Country M/T....Wheels:Gear Alloy , 713 MB, Double Pump, 20 x 9 www.sun1.netwww.dirtycruisers.com
my scuba driving video-http://www.youtube.com/watch?v=k7DPRFMBXDc
TJ Cruiser is offline
Old 04-25-2007, 02:29 AM   #134 (permalink)
Member Number: 11160
Real clean install, Bill, very impressive.
Just a newbie's question to all the CB aficiandos - why a CB when FRS/GRMS handhelds are available?
JV711 is offline
Old 05-04-2007, 02:16 PM   #135 (permalink)
bigbill25's Avatar
Member Number: 1293
JV711 previously said: View Post
Thanks.
CB has a couple things going for it:
  1. Legacy: A lot of off-road rigs have been using CB well before FRS.
  2. Range: CB runs at a higher power (4W vs. 0.5W) and at a lower frequency (27MHz vs 462-467MHz). More power is obviously good. The lower frequency lets the signal "bend" more around obstructions, so it is not quite "line-of-site" as FRS.
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 05-08-2007, 05:44 AM   #136 (permalink)
ruebarb's Avatar
Member Number: 1493
Lightbulb Re: Cobra 75 WXST and Bandi Mount Install
Here’s my alternate install location for the CB and remote box. I didn’t like the idea of installing the CB in the storage box because the box is always being used for other items when I’m driving and also you need to look down to grab the CB. I wanted something that was right in front of me.
NOTE: You will want to wrap the cord with fabric where is hits the plastic, the crappy silver paint wears off from the rubbing.
Items used:
Cobra 75WXST Remote CB & Weather Radio (75WXST)
Garmin Suction Cup Mount for the StreetPilot C510 and C550 (010-10747-00) (pic is wrong on Amazon)
5 - long black zip ties
1 - short black zip tie
1 - Wirthco 30103 Tapa-Circuit- Mini
Garmin mount
I used the small zip tie around the ring and a larger zip tie for hanging. I may at some point buy some wire and bend it to the exact shape I want, but for now this will do.
Location to mount remote box, metal housing for the brake pedal arm
The remote box mount with 2 zip ties zipped together around each side.
Now you need to wire the box to the FJ. Connect the positive to the mini fuse tap and plug into empty fuse slot in fuse panel.
To connect the ground, follow these steps.
Remove the kick panel along the door, pulls up.
Remove the dead pedal, slide your fingers behind the top, grab and pull towards you.
Turn the plastic screw that was under the dead pedal, towards the left, pop off panel on left.
The ground point is under the mess of wires.
Ground point (the bolt)
Attach a U connector to the neg wire, loosen the bolt, slide the connector under the bolt and tighten the bolt. If you do not have a U connector, snip a ring connector and bend it into a U.
Attach the Garmin suction mount to the FJ.
Finished
ruebarb is offline
Old 05-08-2007, 07:16 AM   #137 (permalink)
stnmikita's Avatar
Member Number: 4279
I like this install! Very nice Rhubarb.
Do you find your knees hitting it/knocking it off when you get in and out?
If you can read this, thank a teacher.
If it's in English, thank a soldier.
stnmikita is offline
Old 05-08-2007, 07:55 AM   #138 (permalink)
ruebarb's Avatar
Member Number: 1493
stnmikita previously said: View Post
I actually haven't finished the install yet, I forgot to order the stud mount. So I can't do anything else until I get that part, hopefully Friday I'll get the part.
But I'm a small guy and I sat in the seat, I shouldn't get caught up on the wire getting in an out. The mount is very solid, it won't get knocked off. It takes seconds to connect the cb to the box and stick the mount to the dash.
ruebarb is offline
Old 05-09-2007, 03:38 PM   #139 (permalink)
Terahex's Avatar
Member Number: 1680
Location: HELL ...................... if I don't change my ways :)
Very professional looking solution.
2007 Toyota FJ Cruiser MT6 VooDoo Blue (FE, CQ, GY, RB, UR, CF, C7, V5)
Mods: Kenwood DNX7100 | Expedition One Sliders | OME Medium Lift | Original Bandi Mount | CB | 285 Nitto TerraGrappler | HiJack Roof Mounts | ScanGageII | Rear Door Storage Net | TireCover Mod | PIAA Headlights | Passenger Armrest | VooDoo Tent Trailer
WishList: Skid Plates | Wet Okole
Member: NorthWest FJ Cruiser Club
Terahex is offline
Old 05-10-2007, 08:36 AM   #140 (permalink)
ruebarb's Avatar
Member Number: 1493
Does anyone need instructions on how to install the cable through the inside of the FJ to attach it to the remote box?
ruebarb is offline
