A cross between quasimoto and the elephant man..... But only the good parts!!!!!
Hello chewey46 it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
First, put your FJammer in AUX mode. Turn off your fjammer then hold the text button down until the text screen promt appears. Release the text button and turn your fjammer back on, the aux screen will be displayed. You should then push and release the text button right after you turn on you FJammer. You can now enter text using the audio control button press this and it will move to the next letter. When you've typed in your stuff press and hold the 1 button. turn off your fj, with the key, then turn it back on. your message should be displayed prior to the fjammer text.( you need to be in aux mode)
okay, not exactly sure how i did it but i managed to reset the jammer so that it would now take text again. i tried to dis-connect the battery to reset, no good, but while i was re-shutting off the seatbelt buzzer, i had an idea. not sure which part it was that did it but: i turned the key to "on" but did not start, held down the number "1" button, turned it back off with the key then back on with the key, after i turned it back on with the key i held the "1" button down for about ten seconds. i then did this same procedure with the "text" button. after i did both, i tried to re-input the text and voila! it works now!
you can add a line of text to the fjammer start up screen. you need to turn off your fjammer then hold the text button down until the text screen promt appears. release the text button and turn your fjammer back on. the aux screen will be displayed. you should then push and release the text button.
you can now enter text using the audio control button. when youve typed in your stuff press and hold the 1 button. turn off your fj, with the key, then turn it back on. your message should be displayed prior to the fjammer text.( you need to be in aux mode)
Does the messagge always scroll, or can it be made stationary?
Grok FJ
NON supporting member
But do not worship it,
For it shall pass.
H. L. Mencken
