Old 10-02-2006, 12:37 PM   #121 (permalink)
Not Serious
MissFJ's Avatar
Member Number: 1937
Re: iPod connected directly to FJ Jammer - Installation Instructions
Thanks I'll give that a try! I didn't know about the toggles but I have to removed my ipod since i installed the sucker.
MissFJ is offline
Old 10-02-2006, 03:20 PM   #122 (permalink)
Member Number: 2287
FJZ Man previously said: View Post
The car switch should be from (left to right) up position the second one down. The ipod switch should have both in the up postion.
Really? Mine has all the switches up.
Sun Fusion Auto 4WD - FE, CQ, UR, Z1
Mods: BFG 285 70/17's on stock alloys, Aeroflow headlight covers, FJ3-FRCC Toytec Lift Kit with OME-N71, Demello sliders, dual rear cargo nets, stock tow hitch, DICE iPod kit, Yakima rack with StornCo adapters, SwissArmySUV Overhead map light, 2008 Side Visors
oldskoolboarder is offline
Old 10-02-2006, 07:06 PM   #123 (permalink)
rjp
rjp's Avatar
Member Number: 385
So does iCarKits have the new units yet?
If so, I may as well start the ball rolling in getting mine swapped out.
rjp is offline
Old 10-02-2006, 11:26 PM   #124 (permalink)
Not Serious
MissFJ's Avatar
Member Number: 1937
I'm very bummed updated my itunes/ipod, unplugged everything and redid the whole install. I have no controls through my head unit or steering wheel. The title no longer plays as well. I check and recheck all my connections, everything's tight The unit ends in 06, so it's supposed to be a good unit Calling them tomorrow morning...
MissFJ is offline
Old 10-03-2006, 01:08 AM   #125 (permalink)
Member Number: 2287
I had various problems where I couldn't control the iPod at all, the controls increased volume instead of moving tracks/playlists, non-operation, etc. Also, there's no text. I have '06, latest f/w, reset the iPod, powered down the head unit, etc. They're getting a call from me.
I've left my dash apart cause I don't want to start over...
Old 10-03-2006, 03:32 AM   #126 (permalink)
Corey's Avatar
Member Number: 2902
FYI
1. It says on the bottom of my unit DL1007.
It is dark out now, I will check again later to see if there is another # on it.
2. As mentioned here earlier, do not stuff the DICE unit in behind the head unit.
Run the cable into the glove box and store the DICE in there so you do not have to pull your dash apart again.
3. My dip switches are all in the upper position.
My DICE unit is working as they state by using the buttons on the FJammer to selct next playlist, album, ect.
Try setting your dips all up like mine and see if this helps.
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, snorked, penthouse, so much more, see my website & buildup thread
YotaTech | My Website | My Rigs Build-Up | My Penthouse
Corey is offline
Old 10-03-2006, 07:33 AM   #127 (permalink)
FJ 432's Avatar
Member Number: 1074
Corey previously said: View Post
[b]FYI
[/color]
Ok. I tried it with all of the switches in the up position. The text appears.
Then I turned the unit and the stereo off and waited a minute. Once I powered the stereo back on after about a minute the unit won't recognize the dice adaptor. I unplug then replug the dice adaptor and bingo the unit is running fine. As I mention in my earlier post Dice is sending me a new unit. For those of you that call Dice today I would try the switches in the up position (sorry for the misinformation that I relayed to you via the dice tech) before calling. It may work better but it still doesn't explain why the fjammer "loses" the dice adaptor after you turn off the vehicle. Please keep posting your results. Corey get some sleep
"Pretty please...with sugar on top...clean the f**king car"
FJ 432 is offline
Old 10-03-2006, 07:42 AM   #128 (permalink)
Corey's Avatar
Member Number: 2902
Oh I was up at normal time
Up at 1:30 to 2'ish am Monday - Friday for work.
Corey
2007 FJ Cruiser
Corey is offline
Old 10-03-2006, 11:06 AM   #129 (permalink)
Member Number: 2287
Waiting for a return call from DICE. I tried all 4 combinations. No text. And yes, in btw changing the switches I powered off the DICE to erase the previous settings. Oddly enough, the only change I see is when the both are ON (down). Only then do I see track times, but never any text in any switch position.
UPDATE: 2:30 PM PST. DICE has to send me another unit and I'll try that. Man, this is a bit frustrating, at least DICE is being helpful.
Old 10-03-2006, 02:07 PM   #130 (permalink)
Corey's Avatar
Member Number: 2902
Looks like on the tag on my unit the other # is
A00026-0606
Kind of hard to read, and no magnifying glass here at work.
See if your # looks similar.
Corey
2007 FJ Cruiser
Corey is offline
