Re: iPod connected directly to FJ Jammer - Installation Instructions
Sandi_k previously said:
Tony:
The DiCE unit does use the satellite radio plug.
Sandi
The Dice wiring harness does have a couple of extra wiring ends (termination points) attached to it - no idea if it would work or not but they might allow for both a Sat connection and the iPod.
On the web page, the Neo Ion has a different part number if want use a Sat or external CD Changer in conjunction with the iPod adaptor.
The less than helpful instruction manual, included with the DICe unit, states" NOTE: -External CD/DVD changer or SAT module MUST be disconnected." However, the manual shows a photo of a "Sat radio/ MP3 player / DVD player" plugging into an "Aux" jack on the DICE unit while the iPOD is connected to the "8-pin Din" jack. So, I'm not sure if the "Note" part I quoted above means that the other players have to be disconnected, prior to installation and connected to the DICE unit, or if the other players have to be permanantly disconnected.
FOR THOSE OF YOU WHO HAVE THEIR DICE UNIT IN THE GLOVE BOX, OR WHERE IT'S EASILY ACCESSABLE, CAN YOU PLEASE CHECK AND LET ME KNOW IF THERE IS AN ADDITIONAL INPUT ON THE DICE UNIT? I'd do it but mine is installed behind the dash under the head unit.
Where's that DICE Rep. when you need him??
The only other input on the black box is an additional AUX input - can't say I've tried it but I assume it works (probably a poor assumption). As to the wiring harness, there are two unused connections; if you look at the original pictures at the start of this post, they are the connection ends without numbers beside them. No idea if they can be used or not.
Chalk up another Dice install that hardly works.
Got it all installed without a problem. Fired everything up, worked fine. Shut down the truck and came back the next day, no go.
The only way mine will work is if I turn the truck off, pull the iPod, hard reset the iPod, reconnect it, fire the truck up.
2001 Audi TT
2003 Audi allroad
2007 FJ Cruiser
Sold but not forgotten:
1991 Nissan Pathfinder "Babe the Blue Ox" (the tank)
Some mods on the FJ:
AFE CAI, ProClipUsa iPod and GPS mounts, TRD wheels, Hankook 285 75 16 MT RT03 tires, Expedition One sliders, Expedition One bumper, T-Max 9000 Winch, OME 885 springs in the front, ToyTec springs in the rear, OME shocks all around.
I'm very dissapointed with what I'm hearing about these ipod intergration setups. Really considering aftermarket h/u. Would really prefer the stealthyness of the FJammer. Don't really like the trade off of the VAIS setup and the whole buggyness of the DICE would cause me to drive my truck off the nearest parking garage/cliff!!!
Anyone try any other integration kits??? USA spec etc...
2004 Acura TL 6-Speed
2007 Toyota FJ Cruiser 6-Speed
Had the DICE installed since Mid November. Had Text early on, lost it. Had a few hang-ups like the DICE didn't exist. Unpluged IPOD, turned off Radio, Pulled fuse, re-inserted and back to normal, Minus the Text. May reinstall from scratch and relocate DICE unit to Sat. compartment.
This "attachment" to the"material world" will keep me in samsara.
