Old 08-30-2006, 07:29 PM   #1 (permalink)
Deadvenom's Avatar
Member Number: 5094
Connecting aftermarket sub to fatory radio
anyone have a how to on this...I think i looked over most of the post here.
if i happened to miss it please send me a link.
thanks
Deadvenom is offline
Old 08-30-2006, 08:13 PM   #2 (permalink)
RipsFJ's Avatar
Member Number: 3866
Re: Connecting aftermarket sub to fatory radio
You can use the speaker leads that are used for the stock sub, put a high to low level adaptor that gives you rca's, put those rca's into an amp and the amp will drive your aftermarket sub.
I'm not sure that is what you are looking for, you may want to give some more info.
Black Cherry, Rock Rails, Roof Rack, VIP Alarm, Tint, 3M Protection Film, Tow Hitch & Converter, Pioneer P6800DVD, JL 450/4 Amp, JL 500/1, JL Prowedge, Fosgate 3Sixty.2, Morel Elate 9 speakers, Momo Shift Knob, Nitto Terra Grapplers, TRD Exhaust, QuickShifter, CAI, Shocks/Struts.
RipsFJ is offline
Old 08-30-2006, 08:59 PM   #3 (permalink)
Deadvenom's Avatar
Member Number: 5094
i dont have the option FJ sub so what i plan to do is run the amp wiring kit myself and install a powerd sub (OMEGA) bazooka style sub. My question is how do i add the RCA plugs into the factory.
Old 08-30-2006, 09:39 PM   #4 (permalink)
fj2play's Avatar
Member Number: 5085
OMEGA? Not familiar with that brand. It should have "high level" speaker in though, and maybe even RCA type in.
If it does have "high level" speaker in, then you must run 2 speaker wires from the radio (rear channel would work fine) to the new sub. Connect these to your sub, along with power, ground, and turn on, and you are in business.
You can find the color codes here on this forum for the rear channels. You can also go directly to the rear speakers and tap off of them as well.
The cleaner way to do this would be to replace the factory radio with an aftermarket unit that offers RCA type out connectors. Then make sure your sub accepts RCA type connectors and you know the rest....
fj2play is offline
