Old 08-31-2006, 06:47 PM   #1 (permalink)
Member Number: 3609
Question AVIC-Z1 with stock sub??
Hello everyone!
I have searched through the forums and I haven't found exactly what I am looking for so I thought I would post. Also, before anyone asks why I would use the factory sub? Well, simple....funds. I will be upgrading the speakers at some point....but I need the stock sub to work for now.
I had the AVIC-Z1 installed and the stock sub is not working. I believe I had read through the forums here that this is possible, but I could not find a post for a Z1 (saw D1 and D2, etc). I believe the power will still be getting to my sub via the push-button switch under the head unit (Correct??). I just need to know what to tell my tech to connect for the stock sub to work with the Z1.
Again, I really appreciate the responses!!!
Sean
Ardmore, OK
bonkuba is offline
Old 08-31-2006, 09:22 PM   #2 (permalink)
Member Number: 3609
Re: AVIC-Z1 with stock sub??
Sean
Ardmore, OK
bonkuba is offline
Old 09-01-2006, 01:02 PM   #3 (permalink)
Member Number: 3381
You want to connect the amp power wire(mine was blue/white) from the Z1 to the power antenna wire of the wiring harness. For some reason, Toyota used the power antenna wire to power the sub.
Black Cherry FJ
Electronics: Alpine IVA-W200 - Alpine NVE-N872A - Alpine Ipod Cable - DEI Sirius Tuner with Traffic - PESWIAKJ Steering Wheel Interface - PTR7 Video Bypass. To see my old install of the AVN5500, rear camera, and 12v adapter, click here.
To do List:
Demello Sliders - Suspension Kit - Tires and Rims - CB install(waiting for Bandi mount)
Helevitia is offline
Old 09-02-2006, 09:21 PM   #4 (permalink)
Noisycow's Avatar
Member Number: 3046
Pull it, put this in there ...
Banksters and Jackals. Note: My sig links are often offensive, raunchy or outside the bubble; clicking means leaving the forum; don't likey?, don't whiney. Only you control your browser. 'Pause' at the beginning of a video allows the buffer to fill and means a more pleasurable viewing experience.
Noisycow is offline
