3" lift + 1" body lift???? - Page 2 - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Suspension / Steering Tech
Old 11-25-2012, 04:08 PM   #11 (permalink)
4.5-by-4.5's Avatar
Member Number: 55536
Re: 3" lift + 1" body lift????
wikid are you running 35s on that?
4.5-by-4.5 is offline
Old 11-25-2012, 07:41 PM   #12 (permalink)
Member Number: 60822
i did a 3 and a 1 inch body
it was easy very very easy
hardest part was removing
washer container to get front passenger
bolt out ...
i want to go 1.5 body but you HAVE to have steering rack extension and
radiator drop brackets
PhilthyFJ is offline
Old 11-25-2012, 07:43 PM   #13 (permalink)
and i run 315 75 17
Old 11-25-2012, 08:52 PM   #14 (permalink)
07 Black Fj's Avatar
Member Number: 43638
i am thinking of doing the body lift, can you guys tell me how you delt with the spaceing in the bumpers? Will the rock rails seperate also? pics woiuld be awesome. i have the arb, is it adjustable? i am very curious as i want a little more lift.
2007 Fj Cruiser 4x4 6MT
Sway-a-way w/ All-Pro Upper A-Arms
OME Rear Lift
ARB deluxe front bumper with ipf fogs and hitch
KC explorer lights on ARB
REM9000 Winch w/ warn synthetic line
16" AMERICAN RACING RIMs
Pioneer AVH-P6800DVD
A-TRAC Hacked
Big Bill combo
SCUBA MOD!!!
TRD CAI W/Safari Snorkel
MANIC Light BAR w/ProComp 100W lights
Full set of Ricochet Skid Plates
URD Short Shifter
Discovery Overhead Console
07 Black Fj is offline
Old 11-25-2012, 10:05 PM   #15 (permalink)
THE ROCK
Wikid's Avatar
Member Number: 8494
4.5-by-4.5 previously said: View Post
Yep 315/75/16 Generals
The front bumper space was filled with a rubber trim piece I found online
the rear was easy . The trim I used on the Metaltech tube bumper was already long enough.
The sliders are Demello and they angle up so the inch isn't hardly noticeable
"The Rock"
http://www.fjcruiserforums.com/forum...8490-rock.html
WikidfJ Partially retired
Wikid link
Wikid is offline
Old 11-25-2012, 10:41 PM   #16 (permalink)
4.5-by-4.5's Avatar
Looks great, probably going to do this next tire set.
Sent from my iPhone using AutoGuide.com App
Old 11-26-2012, 12:02 AM   #17 (permalink)
FJX2000's Avatar
Member Number: 52569
Location: Cortez, Colorado (2 Hours away from both the FJ Summit and Moab)
I remember when I was looking at body lifts but finally decided against it. It just seemed like too much work and thatyouwere making changes to the vehicle that would put too much stress on different components.
07 Black Fj previously said: View Post
But I know with the front bumper, all you have to do to adjust it is move the bumper up so it bolts into the next set of holes that are already in the frame. But the back bumper requires cutting of the plastic because when you raise the body, the frame is still in the same place, and the rear bumper is attached to the body, so what happens is the frame then is pressing against the plastic of the bumper on the bottom lip. I've seen pictures on here of what people have to do to make the body lift work and to me, I just didn't want to deal with those changes and modifications. And your rock rails would seperate from your body since they are attached to the frame. So there would be an extra 1" gap between the bottom of your door basically and your rails. And I believe you may be able to adjust your ARB bumper but I don't know.
FJX2000 - Hayden
2007 FJ Cruiser TRD Special Edition AT
See Ya At FJ Summit No.7 & Cruise Moab 2013!!!
Mods: 305/70R16 Fierce Attitudes, ReadyLIFT 3" Lift, Spidertrax, TRD Wheels, KC HiLiGhTs Slimlights, Rocktek Armor, Bushwackers, Blacked Out, LEDs all around, DDM Tuning 8000K HIDs, Light Racing UCAs, and so much more!!!
Go to my GARAGE or click here to see the STORM DAMAGE TRD build thread!
Or check out this thread to see all my FJ's Off-Road Adventures!!!
FJX2000 is offline
Old 11-28-2012, 08:10 PM   #18 (permalink)
front bumper is easy
back bumper looks normal
i did NOT have to trim or move my shroud with a 1 inch
Old 11-29-2012, 04:54 PM   #19 (permalink)
BikeNuke's Avatar
Member Number: 49454
The rear bumper does not need to be cut. I didn't cut mine. I didn't even remove any bolts on it when I installed a 1" body lift. The plastic will flex enough to accommodate it.
BikeNuke is online now
Old 12-20-2012, 06:51 PM   #20 (permalink)
Member Number: 62850
When you guys added the body lift, what type of suspention lift did you have? I still cant decide on which 3" lift to get, but would it matter?
Blankman is offline
