Rear shock replacement on an '07 - Toyota FJ Cruiser Forum
post #1 of 18 (permalink) Old 03-12-2012, 06:56 PM Thread Starter
Quoted: 0 Post(s)
I am going to repalce the rear shocks on my sons FJ. Is it straight forward? or are there any tricks on this vehicle that I should know about in advance? Thanks for your help.
bestman is offline
post #2 of 18 (permalink) Old 03-12-2012, 07:01 PM
SpeedRye's Avatar
Quoted: 204 Post(s)
Re: Rear shock replacement on an '07
Very straight forward. Unbolt the old ones and bolt the new ones back on for the most part. I think I needed my large pliers and a rag to keep the shock from turning while unbolting, but I might be thinking of a different vehicle. When I replaced my rear shocks, it took me about 20 minutes total for both sides, including the time to take the wheels off.
Black 07 6MT Blacked out including roof
Speedrye front bumper, Ricochet under, stock rear
Lighting by TRS, Rigid, Baja Designs & a Chinese sweatshop
Audio by JVC, Infinity, Alpine, Boston, MB Quart
17x9 Liquid Metal Gatlins in black wrapped in Kumho 315/70-17 MT's
Toyota Rock Rails, Toyoutfitters links, URD shifter, Engo 12K synthetic
Toytec/Bilstein/OME suspension lift
Light Racing UCAs and a 4crawler 1.25" body lift
Uniden Pro520XL CB w/ 3' Firestiks up front
SpeedRye is offline
post #3 of 18 (permalink) Old 03-13-2012, 07:55 PM
estille's Avatar
Quoted: 0 Post(s)
We had to cut the OEM ones off. I just replaced a set of BDS rears with no issues.
estille is offline
post #4 of 18 (permalink) Old 03-14-2012, 12:07 PM
Quoted: 5 Post(s)
Err details? Why'd you have to cut them off?
2013 KTM 990 Adventure Baja
1974 Suzuki TS 250
JohnnyNumber5 is offline
post #5 of 18 (permalink) Old 03-14-2012, 12:14 PM
ZFJCruiser's Avatar
Quoted: 53 Post(s)
Easily changed, if fact the change is so easy he could do the change himself...
2014 Iceberg White 4x4 -
2012 Calvary Blue 4x4 - Sold
2007 VooDoo Blue 4x4 - Sold
ZFJCruiser is offline
post #6 of 18 (permalink) Old 03-14-2012, 12:20 PM
Forum Detective
mountain mike's Avatar
Quoted: 102 Post(s)
Depends if the current shock has fused to the mounting bolt or not. If it hasn't it will be easy. If it has get ready for a headache...
One thing you might do is jack up one side of the suspension, which will take some of the pressure off the shock and allow it to come off easier.
mountain mike is offline
post #7 of 18 (permalink) Old 03-14-2012, 06:15 PM
estille's Avatar
Quoted: 0 Post(s)
One side had fused. We cut right under the top nut. The ones I replaced last night were super easy. Hope that helps!
estille is offline
post #8 of 18 (permalink) Old 03-14-2012, 07:07 PM
Forum Detective
Quoted: 102 Post(s)
Make sure to use anti-seize in case you ever have to remove these.
post #9 of 18 (permalink) Old 03-14-2012, 08:19 PM
Quoted: 0 Post(s)
estille previously said: View Post
Wow never heard of that before. crazy.
DCHFJ is offline
post #10 of 18 (permalink) Old 03-14-2012, 09:51 PM
FJ_Wheeler's Avatar
Quoted: 1 Post(s)
I had same problem on one of the shocks when I replaced the rear shocks this past weekend. I even cleaned and presoaked it with WD40 before trying to loosen the top nut. Fortunately I didn't have to cut the shock off, but there no threads left on the shaft.
Otherwise it was fairly easy job.
2007 FJ TRD SE, 3" lift, OME 884 front springs, Toytec rear springs, Bilstein Shocks, Konig Countersteer Offroad Wheels, Toyo 285-75R-16 MT, Ricochet HD Skid, Lucrum winch mount, Moto-Alliance Viper 12,000 winch. M416 trailer, custom lid, Mombasa RTT, ARB Awning.
TLCA # 23521
FJ_Wheeler is offline
Human Verification
