Lift kit installed, experiencing an issue. Please advise - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Suspension / Steering Tech
Old 11-12-2012, 06:50 PM   #1 (permalink)
jluu's Avatar
Member Number: 45322
I installed my front suspension setup over the weekend. Upgraded from my Rough Country 3" lift. Here is what I installed:
OME 885 coils
Bilstein 5100 shocks (on lowest perch, no lift)
Toytec top plate spacers to gain 3" lift
LR UCA's
After installing the suspension, the front end is definitely nose high. I have put on about 200 miles and it has settled a bit. I still have to install bilstein 5100s and toytec superflexs in the rear.
The problem I am having is when I accelerate, especially out of turns (U-turn, freeway on ramp, etc) the front end vibrates and makes a tuh tuh tuh tuh noise and it feels like I am not getting traction from the tires. Now, is this because I have not added more weight up front to support the 885 medium coils? My bumper is currently being built and is about 1 month out. Is this normal for this suspension setup without the additional weight on the front?
08 Sandstorm 4x4 6MT: OME/Toytec lift, LR UCA's, 33" Duratracs, TT TRD wheels, Relentless Fab bumper, B.A.M.F Sliders, Spidertrax 1.25", TRS HID Retrofit, PIAA 510s, aux lights, Cobra 75 CB/Firestik 3', URD short shifter, Amaesing, AFe Pro-Dry, Tuffy, TRD/IMP knobs
jluu is offline
Old 11-12-2012, 06:54 PM   #2 (permalink)
Michigander's Avatar
Member Number: 57983
Re: Lift kit installed, experiencing an issue. Please advise
I can't really help with your problem but was wondering; Is there any reason you went with the spacer instead of using a higher perch on the 1500's.
My Build:07 Black Cherry 6MT
You haven’t really failed, because you haven’t really tried to succeed. So don’t credit yourself as a failure. You’re worse than that.
- Take Me Home Tonight
Michigander is offline
Old 11-12-2012, 06:57 PM   #3 (permalink)
Ivan70's Avatar
Member Number: 35155
Can you post front shot of your truck? Based on the side view even, it appears that your alignment is way off, maybe just an impression, not the case. Did you do alignment? Those KM2`s is riding on the otside lugs will do " tuh tuh tuh tuh noise "
2010 FJC AG 6MT
2005 4Runner SE
My build..slow but consistent
http://www.fjcruiserforums.com/forum...6mt-build.html
www.fjnortheasters.org
Ivan70 is offline
Old 11-12-2012, 07:02 PM   #4 (permalink)
Ivan70's Avatar
P.S. i would rather use dials on the 5100s then top spacers to get back to 3" lift
2010 FJC AG 6MT
2005 4Runner SE
Ivan70 is offline
Old 11-12-2012, 07:02 PM   #5 (permalink)
tgormtx's Avatar
Member Number: 40295
Any time you make major changes to your front suspension, you really need to get an alignment done. I bet your vibration disappear after that.
Tom | TLCA.21835 | Toyota Trail Riders
'10 Iceberg FJ 4x4, A/T, Rear Locker, A-Trac, Convenience Pkg, UpgradePkg #2, TRD Cold Air Intake, Nitto Trail Grappler 285/70/17, Black Rhino Sidewinder Wheels, MetalTech Sliders, Dual Horn, ICON Stage 2+ (Ext. Travel Coilovers w/ Remote Res., Tubular UCAs), ExpOne Diamond Bumper, Ricochet HD Skids Full, SPOD, ExpOne Windshield Fluid Reservoir, Suspension Armor
Vendors that gladly accept my money:
TRDParts4U
Demello Offroad
MetalTech4x4
Ellis Precision
Ricochet Offroad
BaerTrax
Roads? Where we're going, we don't need roads.
tgormtx is offline
Old 11-12-2012, 07:03 PM   #6 (permalink)
jluu's Avatar
Michigander previously said: View Post
Toytec doesn't recommend using the perches with the lift springs. They only recccomend using those settings to level or raise the height with stock springs
jluu is offline
Old 11-12-2012, 07:05 PM   #7 (permalink)
jluu's Avatar
Ivan70 previously said: View Post
I don't currently have a pic of the front. I can tell you though that my alignment has been off for a while and veers to the left.
I am getting it aligned after driving it around for little bit longer to let the suspension settle.
jluu is offline
Old 11-12-2012, 07:06 PM   #8 (permalink)
Ivan70's Avatar
jluu previously said: View Post
Never heard of this... do you have a link to this recommendation?
2010 FJC AG 6MT
2005 4Runner SE
Ivan70 is offline
Old 11-12-2012, 07:07 PM   #9 (permalink)
Ivan70's Avatar
Take her in for alignment when rear lift is done
2010 FJC AG 6MT
2005 4Runner SE
Ivan70 is offline
Old 11-12-2012, 07:10 PM   #10 (permalink)
jluu's Avatar
Yeah, I will look for it later tonight. Before choosing and installing this suspension, I did a good bit of research here and I have found others all say to not use the perches on the billies to lift along with lift springs and to use the toytec spacer instead.
jluu is offline
