best bang for your buck complete 3" lift - Page 3 - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Go Back   Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Suspension / Steering Tech
Old 11-19-2012, 11:31 AM   #21 (permalink)
thebus's Avatar
Member Number: 50214
Re: best bang for your buck complete 3" lift
maybe you can have toytec custom do them black worth a shot.. or get them powder coated make sure it allows for some flex so it doesn't crack on you I wish i had mine done in Yellow
thebus is offline
Old 11-19-2012, 01:52 PM   #22 (permalink)
Jrnottarts's Avatar
Member Number: 58942
Pale Rider previously said: View Post
for a few dollars more you can get the Toytec Ultimate 3" lift...
and as the bus and others have said, being adjustable is a great benefit.
with OME your stuck with what you bought. The ride quality of the Toytecs are fantastic!!!
ToyTec Rocks! 3" Lift installed on 2011 FJ
Ignore previous transmission...I read your install thread! Anybody looking at the Toytec lift needs to read that thread! Fantastic write up!!!! Nicely documented and explained
Link: ToyTec Rocks! 3" Lift installed on 2011 FJ
Jrnottarts is offline
Old 11-19-2012, 02:29 PM   #23 (permalink)
Pale Rider's Avatar
Member Number: 51062
Jrnottarts previously said: View Post
Thank you!
Pale Rider Performance
2011 Shiba Cruiser Build
Pale Rider is offline
Old 11-20-2012, 05:27 PM   #25 (permalink)
FJX2000's Avatar
Member Number: 52569
Location: Cortez, Colorado (2 Hours away from both the FJ Summit and Moab)
It appears that the first one has a diff drop
FJX2000 - Hayden
2007 FJ Cruiser TRD Special Edition AT
See Ya At FJ Summit No.7 & Cruise Moab 2013!!!
Mods: 305/70R16 Fierce Attitudes, ReadyLIFT 3" Lift, Spidertrax, TRD Wheels, KC HiLiGhTs Slimlights, Rocktek Armor, Bushwackers, Blacked Out, LEDs all around, DDM Tuning 8000K HIDs, Light Racing UCAs, and so much more!!!
Go to my GARAGE or click here to see the STORM DAMAGE TRD build thread!
Or check out this thread to see all my FJ's Off-Road Adventures!!!
FJX2000 is offline
Old 11-20-2012, 08:23 PM   #26 (permalink)
hewster's Avatar
Member Number: 51689
Realized the one is not adjustable
hewster is offline
Old 11-20-2012, 09:00 PM   #27 (permalink)
GabeRmrz's Avatar
Member Number: 61695
From the research I have done... I am also on lifting my FJC... And this is what I have narrowed it down to
Upper control arms
Extended travel coil overs upfront
Weld-on spindle gussets
Rear lift springs, about 1.5"
With matching rear shocks...
I'm looking a getting it all camburg (uca's, rear lift springs, with fox shocks)
The gussets I'm looking at total chaos or all pro
Sent from my iPhone using AutoGuide.com Free App
www.REBELOFFROAD.com
2010 Iceberg TRD Edition.Total Chaos UCAs. King Coilovers with Resi up front. Icon Rear Springs. King Shocks with Resi in rear. Borla XR-1. HID Headlights 8000K. AirRaid Thottle Body Spacer. Method Race Wheel NVs All Black. Toyo 35x12.50. Rigid Industries Grille with D2s. A pillar mounted D2s.
GabeRmrz is offline
Old 11-20-2012, 09:44 PM   #28 (permalink)
Member Number: 60822
Got y rough country kit for 170
no shocks needed just springs and front spacers
PhilthyFJ is offline
Old 11-21-2012, 05:53 AM   #29 (permalink)
hewster's Avatar
Went with the Toytec Ultimate.
hewster is offline
Old 11-21-2012, 07:59 AM   #30 (permalink)
The SPOT Moderator
Old Cruiser's Avatar
Member Number: 30549
GabeRmrz previously said: View Post
Upper control arms
Just be aware the Gussets will make the clearance between the stock wheels and the spindles almost touch. this will cause issues with wider tires. Spacers help but increase the arc of the turn which puts you into the pinch welds at the back of the fender unless you add caster
Heres some pics to show you
255/80R17 (pizza cutters- thin tires) stock wheels
315/75R16 (basically a 34.8 x 12" tire)- not even made up since the tire was already contacting the spindle -4.5" Back spacing)
I would suggest a BS of 4.25" or similar
The Crack Rock Toyeti- 2010 "almost stock"...
The Build--> http://www.fjcruiserforums.com/forum...ck-toyeti.html
How to install Tires on Beadlocks
http://www.fjcruiserforums.com/forum...ck-wheels.html
How to install PRP Racing seats using MT set up
http://www.fjcruiserforums.com/forum...-seats-fj.html
Old Cruiser is online now
