Thunk sound from rear suspension, thoughts? - Toyota FJ Cruiser Forum
post #1 of 25 (permalink) Old 01-18-2013, 07:31 PM Thread Starter
jays0n's Avatar
Quoted: 11 Post(s)
Hey gang, this noise is starting to drive me mad so I'm gonna finally try to figure out what it is. When going over a bump, I get a sharp thud in the rear like something is loose. It seems to happen when the suspension unloads. It doesn't happen over all bumps. For example if I'm going slow over a good sized bump I get no noise but going fast I get it every time.
It has plagued me since putting in the 3" SAW lift. I also replaced the sway bar links about the same time so the bar should be back to near stock angles. Every since then this has been happening. I have triple checked that nothing is loose or out of place but can't figure it out. Did the lift change the geometry to a point that this is just what happens kinda thing or am I just missing something?
2007 Sun Fusion | 6MT 4x4 | Nitto Trail Grappler 285/70-R17 | Fuel Wheels | ICON Rear Long Travel | ICON Coilovers | Total Chaos UCA's | TRD Short Shifter | Demello Front Bumper/Sliders | ExpOne Rear Bumper w/swingout | Rotopax | TJM Winch | On-board Air | Rigid Industries Lighting | Rock Lights | Dual Battery | SPOD | MPAC Everything | Better Built SUV Drawer | Kenwood DNX9980HD | JL XD700/5 | JL 10W3v3 | FOCAL 6.5 coax | CST Interior | Offroad trailer with Tepui Autana RTT
jays0n is offline
post #2 of 25 (permalink) Old 01-18-2013, 07:50 PM
CowboyCEO's Avatar
Quoted: 96 Post(s)
Send a message via Yahoo to CowboyCEO Send a message via Skype™ to CowboyCEO
Re: Thunk sound from rear suspension, thoughts?
One time I had a "Thunk" back there. I was 90 miles out in the Mojave when I finally found the culprit. One side of my panhard bar lost it's bolt and it was bouncing off my BozTec diff skid.
Thank's again John
2,007 Sun Fusion / nickname "9-Ball" / Black Leather / K/N filter / Safari Snorkel / Flow master 40 series / 6sp M/T / Hella 550's / Ricochet Skids / Demello sliders/ Boztec diff skid, High Lift hanger and antenna mount / Fire stick / Uniden c/b / Glade Plug-in / Nitto Terra Grappler 285/70/17/, Fox 2 1/2" ext-travel coilovers with resi up front and Fox 2.0 piggybacks in the rear/ Total Chaos U.C.A.s/ Icon springs / All Weather Mats...
200,000 mile club
<a href=http://i580.photobucket.com/albums/ss245/cowboyceo/MrSpinnerScores2.jpg target=_blank>http://i580.photobucket.com/albums/s...nerScores2.jpg</a>
CowboyCEO is offline
post #3 of 25 (permalink) Old 01-19-2013, 07:43 AM
jtmroczk's Avatar
Quoted: 4 Post(s)
The lift didn't change the geometry. Go back and put a wrench on every bolt you touched previously. Did you tighten your upper shock mounts a little more after putting the truck back on the ground?
Lifting does not remove the body mount from the path the tire takes through the wheel well. Lifting does not move that path around the body mount. Lifting only sets the starting point of that path partially below the body mount giving the illusion of clearance. Only alignment and body mount chop can increase tire clearance between the body mount and tire.
07' Titanium Silver 2007 5at 4x2
10' Silver Fresco 2010 6mt 4x4 - Build Thread
05' Black G35 6mt
13' Silver FR-S auto-x toy
jtmroczk is offline
post #4 of 25 (permalink) Old 01-19-2013, 07:46 AM
FJNewb's Avatar
Quoted: 37 Post(s)
Shouldn't be your link mounts otherwise you'd notice the axle steering your vehicle when you got on and off the gas. I'd look at your shocks, swaybar, and panhard
FJNewb is offline
post #5 of 25 (permalink) Old 01-19-2013, 09:31 AM
CowboyCEO's Avatar
Quoted: 96 Post(s)
Oh, Check to see if your bottle jack is snug. If it is even a little loose it can make the described noise.
200,000 mile club
post #6 of 25 (permalink) Old 01-19-2013, 10:32 PM
ROVER1998's Avatar
Quoted: 0 Post(s)
I am having the same problem. It sounds like metal hitting metal, and only happens when I go really fast. It's very annoying. I have the icon stage two, any guesses? There are times when it sounds like its coming from the front. I really can't pinpoint it.
Traded my 07 for 08. I went from silver to black.
Icon Stage 2, Supercharger, BFGAT 285/75/16, Ham radio, cb, blackout kit, trd wheels
ROVER1998 is offline
post #7 of 25 (permalink) Old 01-20-2013, 12:53 PM Thread Starter
jays0n's Avatar
Quoted: 11 Post(s)
Bottle jack is very tight so that's not it. It almost sounds like it happens right AFTER the suspension absorbs the bump. I was unsure how tight the shocks should be, the instructions warned that too tight could cause problems so I tried to follow their instructions. I believe it was a turn or so after the washer stopped moving. Are they too loose? I never touched the panhard bar so I can't imagine that's the culprit. I did remove the sway bar mounts and replace the bushings with graphite impregnated polyurathane, could that be my problem?
jays0n is offline
post #8 of 25 (permalink) Old 01-20-2013, 12:57 PM
FJNewb's Avatar
Quoted: 37 Post(s)
I'd go around with a wrench and make sure your fasteners are all tight. Starting there will be the first step towards identifying the problem
FJNewb is offline
post #9 of 25 (permalink) Old 01-20-2013, 02:34 PM
jtmroczk's Avatar
Quoted: 4 Post(s)
jays0n previously said: View Post
I'm sure the shocks are fine then. You're right, don't over tighten, the stem mount can bend under dull compression if the bushing can't move enough.
05' Black G35 6mt
jtmroczk is offline
post #10 of 25 (permalink) Old 01-22-2013, 12:44 PM Thread Starter
jays0n's Avatar
Quoted: 11 Post(s)
I'll be warming it up in the garage tonight after work and going over all the fasteners again. The last time I did this I didn't find anything loose but will go through it all again. Has anyone ran into issues with the back door rattling at all? I really have no idea what it could be, this is driving me nuts!
jays0n is offline
Human Verification
