TOTAL CHAOS UCA maintenance - Toyota FJ Cruiser Forum
 7Likes
post #1 of 15 (permalink) Old 12-19-2016, 02:21 AM Thread Starter
Quoted: 23 Post(s)
Hello all, i'm fairly new to all this servicing on your own car but i've been trying to devour everything i can on this forum about my new fj. A couple months back i just bought my fj, and since i've put about 5,000 awesome miles on it. I read around and found out i had to grease my TC UCA's every 5,000 miles or so. I called the previous owner to ask when was the last time he had done it. He told me he hasn't done it in a very very long time. So i ordered a grease gun and some redline cv2 grease to grease the UCA's. I gave each zerk about 4 pumps of grease, i think i may have overgreased it.
a) does it matter that i use the redline cv2 grease, even if it's not the original grease that was put into the UCA's? If so should i take them apart and clean them out and regrease them?
b) is grease supposed to come out of the sides of the bushings so i know that it's been greased properly?
c) do these look overgreased (bulging)?
the black grease is the original grease that was on the uca's, i tried to wipe them clean so i could see if the new red grease would ooze out of the sides
ID:	813697   Click image for larger version
ID:	813705   Click image for larger version
ID:	813713   Click image for larger version
ID:	813721   Click image for larger version
Geo Ang is offline
post #2 of 15 (permalink) Old 12-19-2016, 09:10 AM
Iconic_'s Avatar
Quoted: 1382 Post(s)
Re: TOTAL CHAOS UCA maintenance
I dont think you did anything wrong. Maybe a little overgreased but no big deal. There is a pretty good YouTube video on TC UCA maintenance. Maybe you've already found it.
I usually just put a couple pumps in. Often times you can't even see the old grease push out initially. After about a week of driving is when I start to see the old grease come out. Just my experience.
Cruiser47 likes this.
Iconic_ is online now
post #3 of 15 (permalink) Old 12-19-2016, 01:39 PM
MagsCruiser's Avatar
Quoted: 2 Post(s)
Most will loosen the hardware slightly prior to greasing. The washers do not allow for the new grease to expel the old.
Just a thought. I do not think you harmed anything.
Did you get any old grease out? Was there a great deal of pressure on the grease gun? Did you stop when you felt the resistance?
USA4X4 likes this.
2008 TTSE
OME 885/895
Camburg UCAs
BFG KO2's or Yokohama Geolander mt's
HMWS hidden winch plate
ViperMax 13k, AmSteel rope
Richochet skids
MagsCruiser is offline
post #4 of 15 (permalink) Old 12-19-2016, 02:12 PM
ZoSoIV's Avatar
Quoted: 997 Post(s)
and hit the uni-ball with a shot of Tri-Flow now and then
Geo Ang likes this.
ZoSoIV is offline
post #5 of 15 (permalink) Old 12-19-2016, 03:24 PM Thread Starter
Quoted: 23 Post(s)
i've never used a grease gun before this is the first, so compared to when i pumped the grease out without the fitting on yes there was pressure but it was consistent throughout the 4 pumps i gave each zerk.
and no noticable grease came out, i took it for a drive to see if any more grease would come out from it. should i try to loosen the bold the TC uca video recommends? or press on the ball in the zerk fitting to let out some pressure if there is excess? or just leave it as is and let it leak out naturally as i drive after a week or so?
Geo Ang is offline
post #6 of 15 (permalink) Old 12-19-2016, 06:41 PM
Quoted: 2 Post(s)
I would loosen the bolt and give a few more pumps.
If your hardware was tight and you got no grease out, or no resistance, then the bushings are not fully greased.
2008 TTSE
OME 885/895
Camburg UCAs
Richochet skids
post #7 of 15 (permalink) Old 12-19-2016, 08:43 PM
NW FJC's Avatar
Quoted: 292 Post(s)
Goes without saying but, you should wipe the zerk clean before greasing with synthetic grease which won't degrade the UCA bushings... As previously stated, loosen the UCA nut and bolt then grease 'em up and wipe the excess grease off that comes out and tighten things back up, 85 foot lbs or so on the UCA nut.
IDFJ and USA4X4 like this.
_____________________________________________
Nothing screams poor craftsmanship more than wrinkles in your duct tape....
NW FJC is offline
post #8 of 15 (permalink) Old 12-19-2016, 08:51 PM
mikey's Avatar
Quoted: 999 Post(s)
Honestly the best things you can do is when you wash the FJ give the UCA a quick rinse to get rid of any grime/grit.
I finally gave mine a shot of Triflow for the first time in over 4 years. They have never made any noise in that time. I was greasing and lubing everything else to I figured why not them as well.
USA4X4 likes this.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #9 of 15 (permalink) Old 12-19-2016, 09:20 PM
DX FJC's Avatar
Quoted: 95 Post(s)
It will be alright. You will get the feel of it. I use a dry lube on the uniballs too. I have used a few different dry lubes but I have an industrial teflon based aerosol at work that seems to last the longest. I lune the crap out of uniballs and rod ends.
2011 Army Green
3" extended travel Icon coilovers, springs, and shocks
Total Chaos arms front and back
285/70R17 Goodyear MT/R's on stock steel
TRD air box, Safari snorkel, Flowmaster cat back,
Rigid Industries light bar and duallys, Piaa ion fogs and white driving,
Whelen ion strobes, Ricochet skids, Springtail M-pac,
and lots and lots of radio gear
DX FJC is offline
post #10 of 15 (permalink) Old 12-20-2016, 09:59 AM
10851's Avatar
Quoted: 120 Post(s)
One more thing to add to all of the good advice you have gotten.... Another reason for loosening the factory through bolt before greasing is, if you don't, hydraulic pressure created by the grease gun can cause the urethane bushings to deform. This will ruin your bushings... Don't forget to re-torque the factory through bolt to 85 foot pounds...
Cheers
2013 TT FJ Cruiser, Warn front bumper with Warn 9.5 cti, Master Pull Synthetic rope, Factor 55 1.5" Fair lead, Total Chaos Long Travel R series for 3.5" lift, S2 ICON Coil-overs with remote reservoir plus ICON Omega twin tube Bypass with remote reservoir, ICON CDCV rear shocks, ToyTec Super-flex 2.5 HD rear coils, ICON upper & lower links and Panhard bar, Nitro 4.56 R&P, ARB Locker in the front, E locker in the rear, ARB on board air, NorthStar Group 27F, Toyo Open Country MT 285/75/16
10851 is offline
Human Verification
