Alignment shop said adjustable UCA "piece of junk" !? - Toyota FJ Cruiser Forum
 10Likes
post #1 of 11 (permalink) Old 05-19-2017, 12:54 PM Thread Starter
Quoted: 6 Post(s)
Went to a "specialist" truck shop where they do lifts and alignments to have alignment after ToyTec Boss install. I added the SPC / LR
UCAs. Told me they wouldn't do it and they wouldn't waste my time as "Those adjustable UCAs are complete junk. Biggest waste of
money you've spent." - he didn't even look at what was installed.
Any feedback on this please? Didn't want to do because difficult / other?
Where do people go to get alignments and say, here are the recommendations please align to these? Firestone suggested I go to a
"specialist", Goodyear similar.
Cheers!
Db2boy is offline
post #2 of 11 (permalink) Old 05-19-2017, 01:03 PM
LTipton's Avatar
Quoted: 27 Post(s)
Re: Alignment shop said adjustable UCA "piece of junk" !?
I've had mine for about 6 months now and no complaints. I actually just regreased mine the other day. They may be referring to the earlier model SPC LR that was not greasable and some experienced ball joint failures as a result. GL with install.
Line X'ed Top / 33` BF Goodrich AT TKO2 tires / American Outlaw Rims / Old Man EMU 3" lift coil overs / All pro sway bar Links / Steel Wheel fenders / All pro Front steel bumper / Warn Rear steel bumper / Warn Winch / K&N air intake + Filter / Magnaflow Muffler / Custom Y-pipe dual exhaust / OEM Rock Rails / Rear LED brake lights / Jensen CD Player / Full BudBuilt skid plate / Raptor Lined front/rear bumper, wheel fenders and rock rails / Regeared with Nitro 4.88's
LTipton is offline
post #3 of 11 (permalink) Old 05-19-2017, 01:04 PM Thread Starter
Quoted: 6 Post(s)
Thanks! He suggested the weight of the vehicle moves the adjuster and they are never correct. Only thing I could think of is they would be if you didn't
read the instructions and torque...
Db2boy is offline
post #4 of 11 (permalink) Old 05-19-2017, 01:18 PM
StrangerRanger's Avatar
Quoted: 292 Post(s)
There are plenty of members here running SPC/LR upper control arms, including myself. The first generation ball joints had issues, but as far as I can tell they've solved that issue. I'm happy with mine and Town Fair Tire did my alignment no problem. They've been run pretty hard, and no movement so far.
'07 Voodoo 4x4 AT
The Big Blue Build thread
StrangerRanger is offline
post #5 of 11 (permalink) Old 05-19-2017, 01:27 PM Thread Starter
Quoted: 6 Post(s)
Thank you for the info, appreciate it. Guess I need to find a slightly more open minded shop prepared to look first.
Cheers!
Db2boy is offline
post #6 of 11 (permalink) Old 05-19-2017, 01:48 PM
Quoted: 295 Post(s)
So he wouldn't take your money? That's odd. Most shops would take your money and not align it properly. Then you'd have to go in for a 2nd time. The guy was just probably lazy. You should probably talk to another service advisor or another shop. Sometimes talking to one guy might get you an unwanted response and the next guy you talk to, will answer correctly. At any rate, seems like some funky shops in FL. Last thread, another guy had his suspension installed incorrectly by a Jeep shop. Good luck with your search!
jamesepoop is online now
post #7 of 11 (permalink) Old 05-19-2017, 01:56 PM Thread Starter
Quoted: 6 Post(s)
No, and I should give them credit for that as per the situation you point out. I was a little taken back that no one wanted to peek at what was installed and had such a
blanket attitude to "those adjustable UCAs". From a shop that install lifts :-/
Spoke to local Toyota service manager, explained what's fitted and he said piece of cake and no problems for them to do. Off she'll go to Toyota for alignment and rotation.
Db2boy is offline
post #8 of 11 (permalink) Old 05-19-2017, 04:31 PM
debFJVT's Avatar
Quoted: 902 Post(s)
I always go to Toyota for my alignment and they're totally acquainted with my SPC UCA. That guy did you a favor!!
Hopdup likes this.
Member of the Month November 2016
debFJVT is offline
post #9 of 11 (permalink) Old 05-19-2017, 04:33 PM Thread Starter
Quoted: 6 Post(s)
Booked and heading in :-)
debFJVT and Hopdup like this.
Db2boy is offline
post #10 of 11 (permalink) Old 05-19-2017, 05:27 PM
Loganbeere's Avatar
Quoted: 459 Post(s)
Db2boy previously said: View Post
I've had these SPC LR UCA for about 1 1/2 years. They have the newer specride bushings but the older balljoint without the greasable nipple. Never had a problem. Had 4 alignments at the tire shop during that time without any problems. Trick is to tell them what you want for your alignment. Several threads on here about the alignment numbers. Caster around 4, camber and toe around 0
2013 Iceberg AT 4x4
Ghost FJ Build
Instagram: loganbeere
Loganbeere is offline
Human Verification
