If you are looking for alignment information, here are two excellent threads:
Thread 1,
Thread 2.
The first thread had the alignment specs and some good info, but the second thread has some excellent explanations of the FJ alignment -- look for the posts by user "jasonrmorrow".
I finally got mine aligned correctly, again (see post 29).
Okay, my FJ started pulling to the right sometime in the past 2 weeks - steering wheel ****ed a bit off center. I read all the alignment threads I could find here, took it to the dealer with alignment specs in hand and had them re-align it. The dealer just called and said that they did the alignment, but it still pulls right (at least they agree that it does pull!). Now they think it is my after-market tires (BFG 265/75/16 MTs on TRD rims from trdsource). However, they told me that they already tried rotating and cross-rotating the tires with no success. They are going to the FJ overnight and try installing a set of stock wheels off a used one they have on the lot to see if that solves the problem.
I am pretty sure that it did not pull when I got the tires/rims installed (I usually notice everything). I probably put a couple hundred miles on the new tires before I did a little light off-roading "just to test things out
." I can't believe I bent anything on my little off-road jaunt, considering what I have seen people doing with these on this very forum! But maybe?
The only other change I made after installing the new tires/rims was to install a set of Demello sliders, which does require re-routing the brake lines and they are a little tighter than before - any chance the rear brake could be grabbing a little and causing this?
Is there any other explanation for this or anything I could suggest that they try? Hate to treat them like idiots, but I am also afraid this might become a wild goose chase and I am going to get my FJ back a week from now with extra 500 miles on the ODO. Thanks for your help!
