Old 10-24-2006, 06:36 PM   #21 (permalink)
Moderator
Ridge111's Avatar
Member Number: 2612
Re: All-Pro Lift - Installed
RocKrawler previously said: View Post
The front brake lines will be available soon, but the 05+ Tacomas and 07+ FJ's dont require longer front brake lines, the stock length is more than adequate. For people that want matching front lines and the look and strength of the DOT braided lines we will have them out in the near future. We are glad that you are happy with the kit, and apologize for the delays, but as everyone is telling us they are worth the wait.
I would like the lines, front and rear, even if I don't get the lift. Will you be offering them separately? And will the longer rear lines be ok without lifting?
Personally if I'm buying an all-around lift kit, I'd like everything to match front and rear. The braided lines, the color of the springs (ahem ), spring rates, shock stiffness. I want to feel confident that I got a complete matched kit, and not 2 different kits. So far, I've been put off by the front-only, or separate or mismatched front and rear kits. This one's almost there, but I'm waiting a little longer for the finishing touches.
Fwiw, I like red components, or just about anything not black. I want it to make me smile every time I see them as I walk up to it. And I love the look and performance of braided brake lines. Glad you're adding those.
Ridge111 is offline
Old 10-28-2006, 08:10 PM   #22 (permalink)
The Cleaner's Avatar
Member Number: 3210
Wow thats perfect.
The Cleaner is offline
Old 10-29-2006, 05:50 AM   #23 (permalink)
RocKrawler's Avatar
Member Number: 3158
No, the rear lines are not required, nor are the fronts - but people like the look of braided lines so we offer them. We do offer them seperately as well. Also as a side note, the front upper a-arms are not required on US model FJ's as the ball joint angle is identical to the aftermarket arms, but the Canadian FJ's use the Tacoma arm the needs to be swapped out for anything more than 1.5" lift. We still offer them for those that want a strength upgrade (chromoly is still stronger than steel).
RocKrawler is online now
