Old 11-11-2006, 04:48 AM   #1 (permalink)
chukwagen's Avatar
Member Number: 7145
spring compressors
I'm installing my revtek lift myself, and was wondering if there are any good install writeups online for this kit.
Additionally, are there alternatives to actually buying a spring compressor
from Revtek?
Chuck
07 Yellow FJ, revtek 3", all pro bumper w/warn 9.5xp
& synthetic rope.
04 Rubicon on 35" MTR's
chukwagen is offline
Old 11-11-2006, 05:11 AM   #2 (permalink)
1911's Avatar
Member Number: 4994
Re: spring compressors
Search for the several OME coil install threads, as the stock coil removal and compression will be the same for your application.
I don't know what the RevTek spring compressor is like, but there are a large variety and price range of spring compressors available. At the bottom end, you have your Horrible Freight compressors which are just large mild-steel bolts with hooks or eyes to attach on the coils. These are cheap and will work OK for you since you're only compressing the stock coils - the basic set of two will work long enough for your install, but you'll probably throw them away after. You can get similar ones at Northern Tool and lots of other places. IIRC the Horrible Freight ones are about $20/pair.
If you use the bolt kind as described, you'll want an air compressor and an impact wrench to turn the bolts for the actual compression, else you'll be cranking on a ratchet or breaker bar for a long time and you'll have one arm that looks like Popeye's when your done.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
1911 is offline
Old 11-11-2006, 06:05 AM   #3 (permalink)
chukwagen's Avatar
Member Number: 7145
Thanx, 1911....
I do have air tools, so aside from avoiding "popeye"
forearms, should I be concerned with any other gross
safety issues?
I do understand the inherent danger in compressing springs and the need to exercise care.....
....but assuming I'm careful, I'm not unduly risking life
and limb by using the harbor freight cheapies with air tools am I?
I'd like to spend as little as possible on spring compressors.
& synthetic rope.
Old 11-11-2006, 06:13 AM   #4 (permalink)
Valkyrie's Avatar
Member Number: 1873
As much as I hate to help someone cram a spacer in their suspension for cosmetics , I will advise you to don't even screw with it. Just pop out the struts and take them to your local Pep Boys. Grab some coffee and the sports page and an hour later they are done for $20 per side.
You can use the same process when you replace your worn out springs next year.
Well, you're wrong.
Don't like what you're reading here? Click here
Valkyrie is offline
Old 11-11-2006, 06:38 AM   #5 (permalink)
chukwagen's Avatar
Member Number: 7145
Do I have to do the same for the rear?
Sorry for all the Q's guys......I've never worked on these types of vehicles before.
Just my jeep.
& synthetic rope.
Old 11-11-2006, 07:48 AM   #6 (permalink)
20Montana's Avatar
Member Number: 3782
chukwagen previously said: View Post
Just my jeep.
No. The rear's are just springs, not struts. They come out fairly easily. Does the rev tec kit have new springs for the rear, or a spacer?
2007 FJ Crusier, Black Cherry, A/T 4WD.
ARB F Bumper & Warn M8000 Winch.
ToyTec Lift
33-12.5 M/T MTZ's
Classic Lock Wheels
Avatar by US Army
20Montana is offline
Old 11-11-2006, 07:55 AM   #7 (permalink)
20Montana's Avatar
Member Number: 3782
I agree with Valkyrie. Take them to a shop and let them deal with the struts, after you have them off of the vehicle. If that is not an option, and you want a spring compressor, this one from Sears is a really well made compressor for the price. 50 bucks.
Craftsman 90500 Strut Spring Compressor Tool with Built-In Safety Pins at Sears.com
ToyTec Lift
33-12.5 M/T MTZ's
Classic Lock Wheels
Avatar by US Army
Old 11-11-2006, 09:08 AM   #8 (permalink)
chukwagen's Avatar
Member Number: 7145
Thanx, guys...that helps.
I think I'll buy 2 pair from sears.
I'll feel better having 4 of them on a spring at a time.
To answer your question, the Revtek kit just has spacers for the rear,not replacement springs.
& synthetic rope.
Old 11-11-2006, 09:39 AM   #9 (permalink)
Valkyrie's Avatar
Member Number: 1873
1. I doubt you'll be able to fit 4 on a single spring safely.
2. I guess you already had your mind set to attempt your first spring compression without guidance before you asked.
3. Disregard the voices of experience if you must, but having swapped out hundreds of springs, I strognly advise you to take your Sears money and give it to Pep Boys instead.
I refuse to do spring work unless it's using my wall mounted spring compressor (with a safety hoop)... I've witnessed firsthand the results of inexperience and/or inattention while using driveway compressors.
You also need to note the alignment of both the cut ends of the coil and the top plate.
Well, you're wrong.
Valkyrie is offline
Old 11-11-2006, 10:30 AM   #10 (permalink)
Member Number: 6649
Personally I would not put in spacers , not to knock anyone or their lift kits. Going to take the same amount of time to do it, but then you will have a functional system for not much more. jmo
07 FJC Ti. Met. A5,CQ,GY, RB, UR#2, CF, Roof Rack, Silver Stars, Airflow L C, VIP V5, TRD CatBack, MAF Sliders & Skids, Rear HDLCA, XM radio, ARB bumper & Tmax 9000, Total chaos UCA, Icon Stage 1 kit , BFG AT KO's 285/70/17, Bandi mount, Cobra 75 cb, Black tundra door handles,Hella Rallye 4000 compacts
DB'sFJ is offline
