So my local shop won't install my lift, which is kinda good. One... I save money. Two... I learn stuff and get to do it myself. I don't like having other people work on my truck, or anything for that matter.
I am going to attempt an OME lift here soon.
Questions:
Do I need coil compressors?
Where can I buy them? eBay?
Do OME lifts come with install instructions?
Any other useful info please.
Thanks in advance.
(Yes I am a newbie when it comes to coils. Used to leaf springs and torsion bars.)
Re: Coil Compressor Question
Yes.
You can by anything in this world on eBay. You can also buy them at Sears, Northern Tool, Horrible Freight, etc.
Mine didn't.
Thanks in advance.
The search function is your friend. There have been several OME install threads with pictures, instructions, and tips already. Good luck and be safe.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
All I can say is DON'T CHEAP OUT on coil compressors!!!!!!! Buy good ones! The OME springs are strong and need a good quality compressor used on them. These things CAN be dangerous! The best compressors I could find around here were at Napa at about $75.00. Good luck, stay safe!
SF, A/T, Conv Pac,Aeroflow HLC's, Demello sliders, Demello Skid plate, OME 2" lift, BFG A/T, K&N filter, Magnaflow exhaust, KC 100 watt and 130 watt slim lights, Two tone air horn,Demello prerunner bumper, rear tow hitch,Allpro LCA's and Skids, Mile marker PE8000 winch, Amsteel blue winch rope, Delrin fairlead rollers, Demello 2wd tranny skid.
Treadlightly member.
Can't speak to OME, but I didn't need compressors for my Allpros. I did try to use them though to see if it would be easier and they didn't work because the tightness of the coil wouldn't allow the compressor to mount properly. OME's could be different though. Also, for $6 a day you can rent a compressor kit at the autoparts store.
For the rear coils, I DID need to use a compressor to get the new (larger) allpro springs in. The stock ones I could get out no problem (they are smaller).
Two Harbor Freight sets will work. I did not feel they were unsafe. Use 'em, abuse'em, throw them away. I paid $6.99 for each set. We also destroyed a $50 Sears set doing Bills FJ.
Voodoo Blue 4X4 with AT.
Added: Warn M8000, Factory rack, Factory hitch, Toytec lift (FJ3-FRCC), Amp-Fortyone-2 Black Alloy wheels with Nitto Terra Grappler 295/70/17, Cobra 75 WXST, Square Sliders, roof rack light bar with 4 Pro Comp lights, 2 Pro Comp lights on custom tube bumper, FJ battery clamp (Thanx Noisycow).
DIY Projects completed:
Toytec lift install, Sliders, body mount chop,Bandi Mount,hitch & tow ring, roof rack light bar and LCNW style bumper.
The sears compressor is a nice heavy compressor for 50$. Be sure and mark your struts before you take them apart. They will go back together right the first time if you do. You don't need the compressor for the rears with the OME. Get a friend to help move the rear axel up and down. The new springs will go back in without the compressor.
Let us know if you have questions.
When I did my Toytec 3" lift, I just went to Autozone and "rented" their spring compressors. When I ended up needing 4, I just went to another autozone. It's free if you take them back. Besides, who really needs their own spring compressors? Are you planning on de-lifting your truck sometime? If I ever need to change my springs again, off I go to the local autozones. Do yourself a 50 dollar favor and don't buy spring compressors.
Thanks guys. One more... how many do I need? I've heard as many as four being used on one coil??
If you use the cheapo screw type you'll want four.
KE5VTE
TLCA # 16550
