Old 01-13-2009, 12:23 AM   #61
SKINUM's Avatar
Member Number: 18535
Send a message via MSN to SKINUM
Re: King suspension for the FJ Cruiser
Does anyone know what the spring length and rate is? Perhaps 600 x14 or is it a 13" spring?
$22,500
THE BUILD OF SKINUM CLICK HERE TO VIEW
SKINUM is offline
Old 01-13-2009, 10:41 AM   #62
jeshua's Avatar
Member Number: 6888
Not sure on the length but I believe the spring rate to be 550lb.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-13-2009, 10:54 AM   #63
PETEBJ75's Avatar
Member Number: 13110
You can find both 12" & 14" from Kings. Fox uses 12&13" springs
PETEBJ75 is offline
Old 04-19-2009, 02:24 PM   #64
TCao's Avatar
Member Number: 940
SKINUM previously said: View Post
The FJC front coilovers have 14" springs. Mine are built with 550 lb/inch rate (same as stock spring rate). When ordering, you can specify other spring rates such as 600, 650, or 700 lb/inch. I'm pretty sure King can also build the front coilovers with different spring rates for driver's and passenger's side if that's what you need/want.
2007 Ti FJC
TCao is offline
Old 04-19-2009, 02:28 PM   #65
TCao's Avatar
Member Number: 940
Also posted in my build-up page.
After over 40,000 miles, the rubber bushings that came with the King rear shocks developed surface cracks and needed replacement. I was able to find some polyurethane Hyper-Flex bushings from Engergy Suspension. These are universal shock eye bushings, PN 9.8145R (they also come in black). The original rubber bushings are 1.88"OD x .75" thick and the new Hyper-Flex are 1.88" OD x .94" thick. The Hyper-Flex have a .56" ID so I removed the Teflon sleeves for the King rubber bushings. Total cost is less than $7 for all four new bushings. The rear swaybar was disconnected at the frame mount in order for the rear axle to droop down far enough to remove and replace the bushings.
Comparison of rubber and Hyper-Flex bushing (shown with rear shock bushing cap, flat washer, and 1/2-13 Nylok nut)
New bottom Hyper-Flex bushing installed with bushing nipple facing into frame mount (top bushing installed with nipple facing down into frame mount)
New Hyper-Flex bushings installed
These Hyper-Flex bushings should be more durable than rubber ones as they are more impervious to oil and other contaminants.
2007 Ti FJC
TCao is offline
Old 10-26-2009, 02:32 PM   #66
kualenamanao's Avatar
Member Number: 17859
Nevermind questions answered
kualenamanao is offline
Old 11-02-2009, 08:43 PM   #67
Member Number: 27071
1/2 FR spacers does this mean1 half inch spacers and where can i find some
bumpassFJ is offline
