Re: Complete list and Comparison of Lift kits there all here!
Savvyav previously said:
Fab tech
No price given on this, due out now tho' It looks like alot of work and is a perm deal, IE cut cross member to install larger beefy one as stock would be in way of drive line angle etc. Rear is insane looks like the new DR stuff with new joint welded on again looks good, will hold up, just to high a lift for me...which is why i didnt bother with close photos. Ill see it again at SEMA and will crawl under it then.
The Fabtech kit isnt all that bad. Integrated Lower Control Arm Crossmembers with
Differential Skid Plate included
• Offset Ductile Steering knuckles retain stock like turning
radius with minimal track width change
• No disassembly of factory strut assembly required
for installation
• Rack and Pinion is retained in stock position
• Full lift height for proper clearance of 35/1250R17 tires
• Rear system includes coil spring spacers with upper and
lower tubular link arms and trac bar relocation bracket
Install time- 6-7 hours
Welding required- Yes, body mount clearance plate
Holes to drill - 9
Driveshaft modification - No
Brake system modification - No
6" lift looks amazing and will out perform most others with ease.
Reason: Non-supporting dealer.
done searching and cant find the answer......
maybe a dumb question...but I'm an idiot and you already know that...so with that being said
Does getting a lift void a factory or extended warranty from Toyota?
A lift will not Void any warranty. The dealer could refuse to cover some related parts for warranty like a broken axle, or CV boot if it is proven that the lift caused a part to fail.
There is some more information on our website. Click on the link
Trailmaster has a 3" spacer kit that uses CNC front spacers instead of the poly ones that Daystar uses. Poly spacers in rear. Trailmaster 3" Suspension kit - T4620 - $152
Updated Skyjacker info. Skyjacker has 3 kits:
There's a 2" spacer kit that's CNC front/poly rear, like the Trailmaster. Skyjacker FJ Cruiser Value Kit - FJ20MS - $184
They also have a 3" kit that replaces the front struts (minus springs), rear springs, and rear sway bar end links. Uses your stock front springs. Skyjacker FJ Cruiser Performance Strut Kit - FJ730ST - $372
And they have a coilover kit with front coilovers, rear shocks, rear springs, and rear sway bar end links. Skyjacker FJ Cruiser Platinum Series Coilover Kit - FJ730 - $924
