Re: Complete list and Comparison of Lift kits there all here!
not all kits are created equal, infactmost are not good
there are differences between suspension kits and lift kits
and you cannot go by the name to tell
they do not all do the same thing, and the differences can be a mater of safety and wear and tear.
a lift kit does just that, it lifts, it takes in no consideration for origonal geometry of the stock vehicles suspension or steering, it can affect the vehicle with such problems as harsh ride, tire wear, stiff steering or bump steering
also it can affect angles of the driveshaft to pinion amoung others.
they usually are cheap spacer lifts
suspension lifts, on the otherhand, will deal with these issues, they can include quite a few parts depending on how much they deal with them, also they usually replace springs and shocks, or coilovers, as they are dealing with the added leaverage of longer travel suspensions. the better ones start to replace control arms and shock towers as well a A arms
you can look at the suspensions made for the jeep wrangler and see kits from 200 dollars to over 5000, it depends on how much you want the vehicle to work correctly after installation.
Price however is not a quide, the best way to tell is asking someone who has run a certain suspension for a year.
now do not ask a guy who cannot afford to can the susupension and replace it, if he is stuck with it, he will defend it to the end, ask someone who can afford to swap out, they only stick with what works
unfortuanately, we are at this time putting parts on our beloved FJ Cruisers that were designed for a vehicle that uses a version of the frame we use, but little else, so feedback will not be forthcoming for a while. And first impressions usually are not the same as having run it for a year.
unlike the poser, who only lifts his vehicle to shove bigger tires under it, a offroader has a bigger picture in mind, now fortunately for us, Toyota has put a factory locker in tthis vehicle as a option so we are not worried about that and they have seen fit to equipt it with 32 inch tires, that is signifacant to us as we will not have to do drive train mods to get large tires under this thing. So with the lift we are looking mainly for increased articulation and clearence under the wheel wells to take advantage of this. 32 or 33 inch tires do not change the rpm range much so we will not have to deal with regearing our diffs till we start adding 35s or larger.
