Old 07-27-2007, 10:07 PM   #1 (permalink)
bistrelaw's Avatar
Member Number: 9209
Torn between 883s and complete OME lift
I just ordered a set of 883s, but now I started thinking maybe I should have went ahead and did the complete lift. I don't do a lot of serious offroading, so its not like I need a complete lift, I just think it looks more bad ass. I know I will like the improved look the 883s give it, but I fear its going to have me wanting more.
I have 285 BFG ATs on already, and they are pretty stuffed in there with the stock suspension. I think with the 285s, the 883s will open up the front wheel wells some, but it won't have the same effect as with a stock size tire. I feel to get a "lifted" look, I will have to go with an all around lift.
Any input or advice would be appreciated.
Also, I am guestimating that the 883 will cost me around $300 for parts and install, whereas the complete lift would be in the range of $800-900 for parts and install. Is this about right?
bistrelaw is offline
Old 07-27-2007, 10:17 PM   #2 (permalink)
FJinDFW's Avatar
Member Number: 9692
Send a message via Yahoo to FJinDFW
Re: Torn between 883s and complete OME lift
I lifted just the front a couple of months ago and I am now kicking myself for not going ahead and doing a full lift all around. I thought I just wanted it to be level and wanted more room for my Terra Grapplers. Come to think of it, no matter what I do with the FJ, I want more and more and more...Will the sickness ever end.
FJinDFW is offline
Old 07-27-2007, 10:31 PM   #3 (permalink)
White Rim's Avatar
Member Number: 3435
your cost estimate is about right; I have been looking at the OMEs as well.
Personally I think it is probably worth it to have the upgraded rear springs and upgraded shocks all around as well if you are going to go to the trouble at all.
I am not sure of the spring rate of the 883s; I have enquired of ARBUSA.
the 884s and 885 are 590 lbs per inch, the 886s are 660 lbs/inch.
Apparantly the difference between the 884 and 885 is in the shock; I would like to know what that difference is, whether it is stiffer on both compression or rebound or both.
Word seems to be if you have stock bumper to do the 884s, an aftermarket bumper to do the 885s, and if also a winch, maybe the 886s.
The 895s (rears) are 260 lbs per inch.
I am pretty close to doing it, if for no reason other than the increased road safety with less body roll ambiguity in curves (which I think is frankly a hazard with the FJ).
White Rim is offline
Old 07-27-2007, 11:42 PM   #4 (permalink)
slim's Avatar
Member Number: 8636
i have noticed with the 885 895 lift the front isnt bad but the rear is slightly stiffer. and also no picture will do the 885/895 lift justice. its very nice once the vehicle is lifted. the door jam is now near my knee.
No trees were harmed in the making or sending of this message. However a
great number of electrons were terribly inconvenienced.
slim is offline
Old 07-28-2007, 12:02 AM   #5 (permalink)
Bappy's Avatar
Member Number: 12552
With the 883 on the front did it level out the ride? I want to level out my ride and I put bigger rims and tire on so I think it would help out but I don't want the front higher than the back?
Thanks Bappy
2007 Black Diamond 4x4 285/65/18 Motometal and cooper LTZ's Simply SICK PEOPLE SICK!
Bappy is offline
Old 07-28-2007, 04:16 AM   #6 (permalink)
Member Number: 10860
bistrelaw previously said: View Post
Just take a look at photos of both options in the many related threads. If you prefer the looks (which seems to be a big factor in your case) and you have the disposable income, then the answer is obvious, unless you have other mitigating factors like height clearance in parking structures (like in my case) or fear of heights .
Wadi is offline
Old 07-28-2007, 01:14 PM   #7 (permalink)
SupraTuRD's Avatar
Member Number: 7943
Send a message via AIM to SupraTuRD Send a message via Yahoo to SupraTuRD
I just went the 883/TP14 spacer route earlier this week and I couldn't be happier with the results:
http://www.fjcruiserforums.com/forum...fter-pics.html
One of the reasons I went with 883's is the fact that the suspension will remain a lot closer to the original geometry compared to the "3-inch" kits out there. My fj is a daily driver, racking up 60 miles per day on my commute. Only time will tell, but I think driveline wear would be greatly reduced by keeping the suspension and driveline geometry as close to OE as possible. I'm not a hard-core off-roader... I don't do the stuff where I'm scraping up the underside over boulders, so this amount of lift works out perfectly for me.
400 tons @ 80mph = not so good stopping distance.
SupraTuRD is offline
Old 07-28-2007, 02:39 PM   #8 (permalink)
bistrelaw's Avatar
Member Number: 9209
FJinDFW previously said: View Post
That is my fear.
I played around with a jack and a camera to try to get an idea of how each would look. This is what I came up with. The first is stock, second is close to what the 883s would look like, and last is close to what a complete lift would look like.
Thanks for the input guys.
torn-between-883s-complete-ome-lift-img_4349edit.jpg  torn-between-883s-complete-ome-lift-img_4351edit.jpg  torn-between-883s-complete-ome-lift-img_4357edit.jpg
Old 07-28-2007, 07:59 PM   #9 (permalink)
SupraTuRD's Avatar
Member Number: 7943
That is my fear.
FYI, the 2nd pic isn't really a good simulation of the 883 setup... looks like your cinder block jack lifted the front and rear at the same time resulting in a raked stance, which the 883 will not have. 883's should get it very close to level, with a slight rake.
Old 07-28-2007, 08:02 PM   #10 (permalink)
1983FJ60's Avatar
Member Number: 2652
i have both.
i had to pull the OME to make room for a parking garage.
the 883s are the way the fjc should come from the factory.
with that said, a 'lifted' fj with OME behaves more or less stock, as does the 883s.
there's less body roll, and that's what you really benefit from. but the ride can get harsh off road.
my 883s actually give the truck a reversed rake, because i've squashed ALL of my rear springs with towing.
i was once a rich man. spent my fortune on whores and drink.
1983FJ60 is offline
