if you use heavy duty springs you will need to change the front, you do not need to change the back with them though. if you use light or medium you can keep front and rear stocks but you will need a spacer for the front to level it.
__________________ Ligten up, it's the internet.
air previously said:
Quote from: BigDouggieDoug
Lifting without changing shocks will cause your shocks top out when hitting even small bumps-OME shipped the wrong shocks, so I ran heavy springs with OE shocks and had them top out a ton until the correct shocks arrived and were changed.
