Uca And Lca Positions With King Bolt On Kit And Donahoe Uca's
I need some advice.
4 months ago a had a King bolt on kit installed. When I picked it up I noticed the camber was a little positive. I questioned the installer and he assured me it was within specs. Later I had it in the dealer for something unrelated and asked them to check out the alignment and was told it was adjusted as much as it could but it was within spec. So I delt with it until I noticed the tires wearing a little on the outside edge.
So I started looking on the forum and it appeared the answer was to replace the UCA's because the stock ones had limited adjustments and were unable to compensate for the lift. I wondered though, if the camber was positive the UCA was the only adjustment, it would have to be adjusted in and that was kinda against the whole bigger, better, faster, sweeter theory that most aftermarket equipment follows. Right? But, they were shinny and sweet looking so I shelled out the 1300 bucks to have the Donahoe UCA's installed anyways.
After ordering, but prior to having the Donahoes installed, I noticed a couple of threads claiming they did get alignment dialed in without aftermarket UCA's. Several of them referenced adjusting the cam on the LCA. That made sense to me because if the LCA was adjusted out then the UCA wouldn't need to be made shorter and the stock one would work. Well it was too late to cancel the Donahoes but as least I knew they wouldn't need to be made shorter than stock and maybe they could be longer if I wanted them to be.
When I dropped it off I asked if they would be making an adjustment to the LCA and they told me 'yes' and to make a long story short they didn't touch them.
But what they did was shorten the length of the UCA by adjusting them in and lowered the position of the kings so it sat a little lower.
Now I really have no preconceived notions of how it should be other than it should make sense to me and this whole experience has left me with alot of questions.
Any advice?
