Old 09-25-2007, 02:10 PM   #1 (permalink)
ferguson's Avatar
Member Number: 9824
Question Advice? Differential lowering kit
Hey everyone,
Lifted my FJ last weekend 3", and the kit I used contained a 1" lowering kit for the differential. I haven't installed it yet, because it seems as if the stock skid plates won't fit afterward.
The kit is just two long bolts with aluminum spacers that (I assume) fit above the two arms on the front differential, facing forward under the engine. My kit neglected to include instructions.
Did anyone else have a problem with the plates not fitting back on? Can you post a pic of your drop install? I was thinking about getting bushings and longer screws for the plates.
Thanks,
John.
ferguson is offline
Old 09-25-2007, 05:51 PM   #2 (permalink)
1911's Avatar
Member Number: 4994
Re: Advice? Differential lowering kit
No need for the drop kit on an FJC, your CV joint angles are just fine with a 3" lift. The drop kits are made for tacos or 4runners.
KE5VTE
TLCA # 16550
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible - T. E. Lawrence
1911 is offline
Old 09-25-2007, 08:22 PM   #3 (permalink)
EARL97850's Avatar
Member Number: 4649
The knowledge on this forum is just awesome.
Ask and you will receive.
Cya
EARL97850 is offline
Old 09-27-2007, 09:31 AM   #4 (permalink)
ferguson's Avatar
Member Number: 9824
1911 previously said: View Post
Cool, thanks. I'll leave them off, but still keep an eye on the CVs though.
Maybe I can pass the bolts off to someone with a Tacoma.
-John.
ferguson is offline
Old 09-27-2007, 01:15 PM   #5 (permalink)
BeerHat's Avatar
Member Number: 11855
I wonder if they are the same bolts as the 2000-06 Tundras. When I had my tundra, the CV's would spit grease everywhere if the angles got off by a couple inches above stock. If so, I am sure someone over on tundra solutions would want them.
2007 FJ Cruiser:
RockTek Front Bumper & Tail Lights
Camburg Full Susp. System
Tranny Crossmember mod
Modified BudBuilt skids
Rocky Road Sliders
255/75/17 BFG M/T
up next: man-a-fre upper/lower high angle rear links
Proud Member of Toyota Trail Riders
BeerHat is offline
Old 09-28-2007, 12:26 AM   #6 (permalink)
ferguson's Avatar
Member Number: 9824
BeerHat previously said: View Post
They might be the same, just a big bolt and thick washer really. There's a handful of Tacomas in my local 4x4 club, NTORA.ORG I'll try to pawn them off at our next ride. If not, then I'll put them up on the forums. I only paid $200 for the whole kit, so I'm not gonna be greedy with them.
ferguson is offline
Old 01-24-2008, 06:15 PM   #7 (permalink)
Member Number: 3024
Has anyone installed the differential lowering kits yet? My inner CV boot is leaking from the clamp (the clamp is on tight), so the ARB tech suggested that the OME Mediums offer a little bit too much lift on my truck as I do not have the additional weight of an aftermarket bumper or winch. I might end up doing this to save the CVs and the boots from eventually tearing.
sunfusion07 is offline
Old 01-24-2008, 10:45 PM   #8 (permalink)
underthehood's Avatar
Member Number: 15067
I have installed them on the Tacomas before. Yes the skid plate makes contact but all you have to do is keep tightening the skid plate bolts and the plate bends to fit. No problems. Hope this helps.
underthehood is offline
