Re: OEM Jack still high enough after the 3in lift?
The OEM jack is used on the axle or lower control arm and is not greatly affected by a lift. Taller tires will raise the axle higher off the ground. 33" tires will raise the axle 1/2", 34" tires will raise the axle 1", 35" tires - 1-1/2", and so on. The OEM jack should have no problems with these on a flat surface like a driveway or street. A Hi-Lift jack is useful on uneven surfaces where you are jacking from the frame, bumpers or wheels using special attachements. The OEM jack will be useful around town, not so much offroad.
"Wherever you go, there you are."
-- Buckaroo Bonzai, 1984
